Block Heater Amperage Draw
Old Nov 6, 2002 | 09:52 PM
rednekf350's Avatar
rednekf350
Does anyone know how many amps the block heater draws?
My nearest outlet is inside my garage but I have a few things on the circuit already like a large freezer, lights and workbench outlets.
Most likely only the freezer would be on late at night when I'm plugged in to block heater, and freezer shouldn't be coming on much when its extremely cold anyway.
Anybody know?
Scott
Old Nov 6, 2002 | 11:32 PM
ColtM4's Avatar
ColtM4
the block heather is 2000 Watts so the amp draw is about 20 amps
Old Nov 7, 2002 | 12:04 AM
Mil1ion's Avatar
Mil1ion
Less than that.
Some are 500W some are 1000W with some in between.
I can run a 75 Heavy gauge extension cord to TWO block heaters on a 15 amp breaker without tripping it.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 7, 2002 | 02:39 AM
ColtM4's Avatar
ColtM4
I thought the diesel manual says 2000 watts for a 2002. Maybe I'm mistaken. I was wondering where to get a timer that would take that kind of a draw...
Old Nov 7, 2002 | 03:24 AM
BlueOvalBoy's Avatar
BlueOvalBoy
Scott,
Run a dedicated circuit for that heater. 2000 watts is what it will take at the most. I have two deep chest freezers that were reeking havoc with the block heater. Didn't matter which of the two freezer circuits I used. Nothing like popping the freezer circuit and having to reset it while warming up the cold diesel at 5am.
99.5 Ford Super Duty F-250 XLT 4x4. S/C L.W.B. PSD Auto loaded.
4 in. Pro-Comp lift. 35 x 12.5 x 16.5 BFG AT/KO. Weld SSII 16.5 x 9.75. Rancho 9000's Dual Front.
Warn M12000 in Semi-hidden mount. Astro-start Supreme 3001.
Old Nov 7, 2002 | 09:33 AM
The Diesel Dude's Avatar
The Diesel Dude
It is stamped on to the side of the block heater but you may have to remove it to see it (you'll lose your antifreeze if you do). I was thinking it is a 600 watt heater (5 amps). If we still have one laying around, I'll look tonight when I go to work and report back on this forum.
Old Nov 7, 2002 | 04:47 PM
Mil1ion's Avatar
Mil1ion
[b][link:www.google.ca/search?hl=en&ie=UTF-8&oe=UTF-8&q=Ford+Diesel+++block+heater&btnG=Google+Search& meta=|Block Heaters]
[/font]
Old Nov 7, 2002 | 05:41 PM
13MWZ's Avatar
13MWZ
ColtM4, I use a timer that I bought from Wallmart. It's the same type of thing as you would use to set your christmas lights (if you do that type of thing) to come on at a certain time. Being the 'Holiday Season' they should be plentifull in the Christmas decoration part of the store.
Old Nov 7, 2002 | 10:34 PM
Firemandan's Avatar
Firemandan
I also bought my timer at Wal Mart. It works great. You can plug the block heater in when you get home and wont start heating until you want it to. Where I live the power is getting spendy. On the days I work I have the timer set to go on about 4 hours before I half to leave and the truck is toasty warm when I start it.
2000 F350 superduty
crew cab Lariat
Power stroke Firemandan:P
Old Nov 7, 2002 | 10:35 PM
The Diesel Dude
The stock, factory block heater is 1000 watts which is 8.33 amps at 120 volts.
Old Nov 7, 2002 | 10:47 PM
EricFriend's Avatar
EricFriend
I just got my used '99 Ford F250, 7.3 home tonight. I looked behind the bumper for the block heater plug and could not locate it. Am I looking in the right spot? An owners manual did not come with the truck.
Thanks!
Old Nov 8, 2002 | 06:47 AM
MikeFrank's Avatar
MikeFrank
Your plug should be inside the engine compartment on the right had side of fan shroud area
Old Nov 8, 2002 | 01:10 PM
The Diesel Dude
There was one year where the block heater was a dealer installed option on some vehicles. Look on the rear oil cooler header just above the oil filter. If there is a block heater it will have a wire attached there. Just follow the wire to the other end. If there is no block heater it will have a big pipe plug in its place about one inch in diameter.
Old Nov 8, 2002 | 04:00 PM
13MWZ's Avatar
13MWZ
The block heaters were an option in 97, but standard in the PSD's before and after 97 as I understand it. My 97 had one from the factory.
Old Nov 8, 2002 | 07:18 PM
greenhighboy's Avatar
greenhighboy
