antifreeze leak
Old Apr 16, 2004 | 07:16 AM
charles l thomas's Avatar
charles l thomas
antifreeze leak
I am about to purchase a 91 Ranger XLT-There is a small plastic hose attached to the heater hose that goes around the motor and it is busted and all the antifreeze pours put-Any idea what this hoes does and can it be temporarily bypassed to get the truck home?
Old Apr 16, 2004 | 07:44 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
You should be able to bypass it by plugging it or connecting the two heater hoses together. Pull one off the heater core connection and the other heater hose off the engine connection. Then connect the one from the heater core to the engine. This will bypass the heater until you figure out what the plastic hose does. In general, plastic is not used for coolant since the temperature of the coolant (200-240F) makes most plastic too soft.
Old Apr 16, 2004 | 08:27 AM
charles l thomas
Well it looks like this little tubing (which tees off the heater hose-goes down behind the motor to maybe cool the trans-altho it's a manual trans-would it hurt anything to temporarily bypass that?)
Old Apr 16, 2004 | 12:32 PM
TotallyRoosted's Avatar
TotallyRoosted
well if its a manual it has no ties to the cooling system..... how small is the tubing?
NOT SURE on this one..... but most other cars have a small coolant hose that goes to the throttle body...... can you trace it up?
Joe
Old Apr 16, 2004 | 02:36 PM
charles l thomas
it's 3/8 tubing and looks like it goes down to the frame somewhere-guess I'll hafta crawl up under there-Thanks
Old Apr 16, 2004 | 07:13 PM
valo's Avatar
valo
is this truck from some where where it freezes?
Old Apr 19, 2004 | 06:06 AM
charles l thomas
yes-Tennessee-Thanks
