Aerostar Ford Aerostar
Vacuum Modulator replacement, Help please.
Old Apr 15, 2004 | 08:50 PM
Vegas Van's Avatar
Vegas Van
Question Vacuum Modulator replacement, Help please.
Please..
Could somebody help me in replacing the Vacuum Modulator on my 95 Aerostar. I am sure that it needs replacing because the vacuum tube has alot of fluid in it,and shifts are changing. My Haynes manual does not cover changing this part out at all. I see that it is very close to exhaust.Does the exhaust need to be removed in order to change the modulator ? What holds the modulator to the trans ?
Also I read the post from last year about the modulator from Napa auto parts that is adjustable and the problems setting it. Would a part bought from Ford be a direct swap?
Any help would be greatly appreciated.
Old Apr 16, 2004 | 08:51 AM
agelder's Avatar
agelder
It's quite easy, but I suggest getting an adjustable model, since there were several versions used. The exhaust can stay, just make sure you let it sit overnight before you start. Have a (10mm I think) socket set with extensions handy (a 1/4 stubby would be ideal due to space considerations. It's just a single bolt holding a bracket down that keeps it in. MAKE SURE YOU DO NOT LOSE THE PIN that's in the old modulator, you'll need it. The old one was pretty stuck, but some prying w/a screwdriver took it out quickly. Remove the pin, put it in the new one, lube it with transmission fluid, toss it back on!
Old Apr 17, 2004 | 01:13 AM
Vegas Van's Avatar
Vegas Van
Thank you, Agelder
My wife and I love this van ,and are very happy that our problem is this small part and not an overhaul. Thanks for your help.
Old Apr 17, 2004 | 09:43 PM
agelder's Avatar
agelder
Not a problem, just passing on my experience from info learned here!
Old Apr 18, 2004 | 07:47 PM
Vegas Van's Avatar
Vegas Van
Thumbs up
10mm ratchet,10 minutes, and our van is back running stong.
Thanks again for the info.
BigSexy78
Feb 14, 2017 10:34 AM
jim33067
Aerostar
Sep 8, 2016 03:59 PM
xtal_01
Sep 13, 2014 12:42 AM
F-250 WARHORSE
Sep 11, 2011 09:42 AM
George Frasier
Jul 18, 2010 06:19 PM
