testing glow plugs?
Old Apr 15, 2004 | 04:01 PM
rugburn's Avatar
rugburn
testing glow plugs?
hey guys, how do test a glow plug to see if it is bad? thanks in advance, john
Old Apr 15, 2004 | 08:50 PM
84deisel's Avatar
84deisel
here sometimes
To do my test you need the glowplugs out of the truck. connect a wire around threads and connect to battery negative then while holding glowplug by the threads and ground wire touch stud or terminal end to pos of battery. The plug should immeadatly get hot and might spark when touching pos terminal. No spark no heat =no good
Old Apr 15, 2004 | 09:47 PM
redneckmechnic's Avatar
redneckmechnic
an easier way is to take a test light and hook one end to the pos of yar battery. take the other end to the glow plug terminal. and touch it if the light comes on good plug no light burnt plug.
Old Apr 16, 2004 | 05:54 PM
rugburn's Avatar
rugburn
thank you for the help. checked the plugs with a test light and all tested good but one. will one bad plug make for a hard start in the morning?
Old Apr 17, 2004 | 12:13 PM
Spectramac's Avatar
Spectramac
One bad plug will shorten the cycle time and make for a harder start.
Old Apr 17, 2004 | 02:15 PM
rugburn's Avatar
rugburn
i replaced the bad plug but i still have a short cycle (3-4secs) the truck has a hard time starting even when it is warm on occasion. new oversize napa batts, new alternator, regulator and belts. it turns over slowly, and sometimes when i turn off the key wait a few secs and try again it will start up, any suggestions? thanks, john
Old Apr 17, 2004 | 06:18 PM
84deisel's Avatar
84deisel
here sometimes
try checking bat connections at starter. Or it could be a bad starter. If you have the delco starter it is usually slower than the more exspensive mitubishi starter.
Old Apr 17, 2004 | 07:43 PM
rugburn's Avatar
rugburn
thanks 84diesel, i will check starter connections in the morning. it would be nice if thats all it is, but with this truck so far if it could be bad it ussually is, thaks, john
Padlock
Oct 26, 2014 08:09 AM
rcorcich
Jan 17, 2010 08:00 PM
Hangfire
Jun 20, 2005 06:40 AM
countrysF250
25
Mar 16, 2005 05:15 AM
sexwax
31
Feb 14, 2004 01:47 PM
