Sponsored by: Auxito
a/c not engaging
Old Apr 15, 2004 | 03:46 PM
Copper 118's Avatar
Copper 118
a/c not engaging
97 F250LD....4.6.....with 97k.....clicked on the a/c today to see how it was working.....nothing happened....the blower works along with heat, but the a/c compressor not kicking on....any thoughts??
Old Apr 15, 2004 | 05:11 PM
BrianA's Avatar
BrianA
Charge low? I believe there is a low pressure cut out that will prevent the compressor from turning on if the charge is low.
Old Apr 15, 2004 | 11:04 PM
1979ford's Avatar
1979ford
Tap on your low side pressure switch, its probably just stuck. It will usually work for a while after that.
