offy intake question
Old Apr 14, 2004 | 08:16 PM
my79f's Avatar
my79f
well i just got my offy dp manifold and there are two different sized holes with threads on the back of the manifold right under the opening. what do those do ?? also when you hold the manifold level the opening where the carb goes is slanted, just enough to where you can only see when you hold the manifold level. also with the edelbrock 500 cfm carb what is the best set up on that.
Old Apr 15, 2004 | 03:08 PM
Oscar Meier's Avatar
Oscar Meier
Look on www.fordsix.com forum - there is a giant discussion going on with the subject being your question - good luck!
Old Apr 15, 2004 | 11:30 PM
GeneStoner's Avatar
GeneStoner
Not quite sure of what EXACTLY you are talking about, but it sounds like you are talking about the vacuum ports.
Old Apr 16, 2004 | 08:37 AM
Oscar Meier
Oh - thoes are vacuum ports. For question on mounting your carb - see fordsix discussion.
