Sponsored by: Real Truck
leveling kit
Old Apr 14, 2004 | 06:52 PM
robbie1's Avatar
robbie1
leveling kit
Looking for a leveling kit that will give me 2 1/2 inches in the front of my 2003 F-250sd ext cab 4x4 with 5.4. I have read that some 2 1/2 inch leveling kits actually give you more than 2 1/2 inches, but I need 2 1/2 and no more to be level, any input on different kits and what they really did as far as lift would be appreciated.
Thanks
Old Apr 14, 2004 | 07:00 PM
CAT_man_963's Avatar
CAT_man_963
Check out one of the kits that re-locates the factory springs with a bracket in the front and longer shackles. Then you KNOW the lift you'll get and still have the factory ride!
Old Apr 14, 2004 | 07:53 PM
mck2000's Avatar
mck2000
donahoe racing thats what ive been told and have read good stuff.
Old Apr 14, 2004 | 08:39 PM
dukota's Avatar
dukota
Recently put a leveling kit on my 2000 SD/ diesel and it really gave me 3.25 but I don't mind.
Old Apr 14, 2004 | 08:41 PM
dukota's Avatar
dukota
Leveling kit.
Old Apr 14, 2004 | 09:39 PM
02superstroker's Avatar
02superstroker
check out this thread:
Hanger Lifts
Old Apr 14, 2004 | 09:55 PM
10 pipes racing's Avatar
10 pipes racing
bds make a nice leveling kit. got one on mine for the bigger tires. sorry no pics yet, scanner broke. soon though. good luck. got a v10 so front is light, nice ride though.
Old Apr 15, 2004 | 06:43 PM
Bashlin's Avatar
Bashlin
Buy the 2" blocks from Ford around 44.00 each and 4 new u-bolts, not a real hard job to install, and you keep the factory ride.
Old Apr 15, 2004 | 07:35 PM
akford351's Avatar
akford351
Blocks on the front springs are a no-no...
Old Apr 15, 2004 | 08:34 PM
LilBlackCoupe's Avatar
LilBlackCoupe
Why are blocks a no no??
Old Apr 15, 2004 | 09:05 PM
kevsf250's Avatar
kevsf250
i happen to have 2" inch hangers and shackles for sale. can email at kevsf250@yahoo.com have pictures
Old Apr 15, 2004 | 10:05 PM
Yeti's Avatar
Yeti
Let alone they are illegal in some states,
When used on the front axle, blocks are subjected to increased side loads when cornering, which can cause them to fail by “rolling out” from under the springs. This, in turn, will cause a loss of vehicle control. Most blocks are tapered. If the tall end is installed facing towards front-of- vehicle, it worsens caster angle; if the tall end faces rear it worsens driveshaft angle. Most factory front springs are fairly weak. Blocks increase the leverage load on these already weak springs which really compounds spring /axle wrap-up,and amount of tourqe when steering.
Old Apr 16, 2004 | 01:01 AM
duckhacker's Avatar
duckhacker
how difficult are these to install?
and I have heard of a x spring. what is this and is it better or worse than a hanger/shackle kit?
Old Apr 16, 2004 | 01:33 AM
Yeti's Avatar
Yeti
Huh??
How difficult is which to install?
You have or haven't heard of an Xspring?
Old Apr 16, 2004 | 10:19 AM
duckhacker's Avatar
duckhacker
I don't know what an x spring is, and I was speaking of a hanger/shackle install. I have done them on other vehicles and I would rate them as pretty easy. I just didn't know if there was anything unexpected on a 250.
thanks
