c6 internals
Old Apr 14, 2004 | 03:47 PM
gunnabebad's Avatar
gunnabebad
c6 internals
will the internals of a big block c6 fit in a fe c6 with a round bell housing. i have a burned up fe c6 that i need and a big block c6 that works that i dont need. can i take the internals out of the working trans and put them in the other trans case that i need? this is going in a 63 f100 with a 390.
thanks for the help!!!
Old Apr 14, 2004 | 07:04 PM
mark a.'s Avatar
mark a.
Yes they will however, there are 2 different low reverse pistons types. They must be kept with the case they came from if there different. I'd recomend removing the piston, it holds a lot of fluid behind it, and if the trans burned up there will be poluted oil behind it. I'd also check the gear train endplay.
Old Apr 15, 2004 | 01:01 PM
gunnabebad's Avatar
gunnabebad
how hard would you say swaping the guts out is. i rebuilt the motor in front of it myself but question my abilities inside a trans. if im going to have to transfer everyone of the kazzilion parts one by one i dont think it would be worth the trouble thanks for the help.
Old Apr 16, 2004 | 12:12 AM
mark a.'s Avatar
mark a.
Get yourself a Haynes manual. C6 Isn't a very complicated trans.You might as well put a rebuild kit in it when you have it that far apart.
