1978 - 1996 Big Bronco
Radiator leak
Old Apr 14, 2004 | 01:19 PM
broncobillybob's Avatar
broncobillybob
Radiator leak
Hey guys,
My radiator has a fast leak, like you put in fresh antifreeze and two days later it is all gone! Anyone know if there is a 'stop leak' substance for radiators? I looked down the backside of it and you can see where it leaks out. Near the top, just below the opening (3 inches or so?) and the second one way down the bottom, where there is as a metal tube entering. It has a large nut around it where it meets the radiator. Is there a seal or need a good tightening? Man, the repair list is never ending seems like.......
-BBB
Old Apr 14, 2004 | 01:45 PM
ksparks's Avatar
ksparks
There are Radiator/Coolant System Stop Leak products at most automotive supply places...but their actual reliability is questionable. I used them successfully on a 89 Chevy Cavalier that had a crack somewhere in the engine...if that didn't work it was going to the junkyard. But I'm confident the leak was something of a hairline crack. What you have described seems larger and I would be doubtful if the Stop-Leak would work.
Sounds like your lower leak is where the transmission cooler lines may enter. Did you try tightening the fitting?
Higher up may be the actual radiator and possibly not much help. Are you sure it's not a hose actually leaking? I've had that before and thought it was the radiator.
Old Apr 14, 2004 | 02:22 PM
Broncobirdy's Avatar
Broncobirdy
I tried w/out success on a small leak in my rad. I ended up getting a new rad. Good luck. I have heard that too many treatments can clog the water jackets in the heads, not sure just heard. Be careful...
Old Apr 14, 2004 | 04:36 PM
broncobillybob
Be careful...for real, broken stuff b/c of yours truly suxs . Yeah, me and my dad tried tightening all the hose clamps already....I'll look into checking them real good. Haven't tried adjusting the fitting, afraid I might screw it up (pun not intended lol). I try rechecking the clamps and fitting later this after noon. I'll keep yall posted. Thanks.
-BBB
Old Apr 14, 2004 | 10:18 PM
93BigBlackBronco's Avatar
93BigBlackBronco
Stop leak works on small stuff but is only temporary sounds like you need a new radiator.
Stop leak also settles into bottom of radiator and reduce cooling capacity if you use a lot. good luck
Old Apr 15, 2004 | 01:28 AM
jambroson's Avatar
jambroson
My radiator leaked also. It leaked from the gasket where the metal radiator meets the plastic tanks. I took it into a shop and they cored the radiator and inserted a new gasket. Worked like a charm.
Josh
Old Apr 15, 2004 | 01:29 AM
jambroson's Avatar
jambroson
Forgot to mention that I only paid $50.
Old Apr 15, 2004 | 07:47 AM
broncobillybob
Checked hoses and one needed tightening. Tried to adjust fitting but none of the wrenches were big enough. $50? I only hope I can be so fortunate. -BBB
Old Apr 15, 2004 | 08:40 AM
JBronco's Avatar
JBronco
Pepper works the best as a stop leak and it's basically free too. I had a 66 F100 that sprang a leak in the core on the way to work one day, I put a few packets of pepper in it that I got free from 7-11 and drove it home that evening. It never leaked again.
Old Apr 15, 2004 | 12:12 PM
broncobillybob
Talked to a mechanic today and he said it could be the water pump. gonna watch the truck for a couple of days and take it back.
Old Apr 15, 2004 | 12:58 PM
Tidybowlman0's Avatar
Tidybowlman0
With where you are seeing the antifreeze I don't think it's the water pump. Unless you are doing really fast reverse driving.
The leak at the top is most likley it. the one at the bottom is most likley run off from the top leak.
sounds like you need a radiator
Old Apr 15, 2004 | 03:10 PM
broncobillybob
Say it ain't so, that's definitely the last thing I wanted to hear. We'll see what it does in the next couple of days. Don't want to spring for the big bucks yet. -BBB
Old Apr 15, 2004 | 06:36 PM
ALSAIR's Avatar
ALSAIR
Yeah that top NUT is the transmission cooling line and there are rubber washers there that probably need to be replaced. Take the radiator out and bring it to a shop and let them pressure test it for ya, couple bucks and you will definetly find where it is leaking from. On all three of my fords, the heater hose fittings out of the water pump and intake have been corroded and leaked down onto the water pump, making it look like the water pump leaking. If it is leaking that fast, put straight water in it and wait for the rust stain to form somewhere in the engine compartment, then you'll find the leak!
She Ain't Revved Ti'll The Rods Are Thrown!
Al
Old Apr 15, 2004 | 06:50 PM
Tidybowlman0
Alsair has a good idea about the pressure test. I would just drive the truck to the shop and have them pressure test the entire system it should cost the same.
Old Apr 15, 2004 | 07:37 PM
Tidybowlman0
I found a new radiator for your Bronco at radiator.com
lifetime $174
1 year $154
thay have a toll free # 800-248-8720
good luck
