Engine Identification
Old Apr 14, 2004 | 12:30 PM
chitown65's Avatar
chitown65
I am knew to Ford small blocks. Where is the stamping to determine what size motor I have? It is a V8 and probably a 289/302.
Also are there identifying numbers on the Ford auto transmissions? It is a three speed auto.
Thanks.
Old Apr 14, 2004 | 05:22 PM
joners's Avatar
joners
and http://www.bulkpart.com/fordid.html
As for engine identification, you might have to pull the valve covers off and look at the casting number. Maybe there is another way tho.
Old Apr 14, 2004 | 11:11 PM
56_Toy's Avatar
56_Toy
The 289/302 block will have a casting # on a flat surface behind the starter.
Unfortunately you have to drop the starter to see it but at least its just a couple of bolts.
Hope that helps, Adam
Old Apr 14, 2004 | 11:58 PM
mtflat's Avatar
mtflat
Down in the engine forum there are several threads on engine ID's, but here's a quick rule of thumb. Count the bolts on a valve cover.
FE's - 5 bolts (390, etc)
Windsors - 6 bolts (289/302/351)
385 family - 7 bolts (429/460)
335 family - 8 bolts (351M/400)
Old Apr 15, 2004 | 07:49 AM
chitown65's Avatar
chitown65
Thanks for the info *NM*
Thanks for the info.
mblanken881
Jun 18, 2014 05:48 PM
kms888
1983 - 2012 Ranger & B-Series
Mar 8, 2012 12:27 PM
less
Mar 22, 2010 02:24 PM
bc56845
Feb 11, 2007 08:44 PM
Ford Truck Racer
Oct 30, 2006 08:39 PM
