Oil & Lubrication
Fram Fleetguard
Old Apr 14, 2004 | 12:15 PM
FERacing66's Avatar
FERacing66
Question Fram Fleetguard
hey just bought one of them fram flletguard oil filters and am wonderin if theres anything bad about them?
Old Apr 14, 2004 | 12:24 PM
68torino's Avatar
68torino
Some do not like Fram filters and some do. I do not as I have seen problems like lifter noise on start up using them. I have switched to Motorcraft, Napa or in a pinch Super Tech filters. If I had a good place to get some I would run Wix as they are also good.
Will it hurt anything to use? Most likely not.
Old Apr 14, 2004 | 03:03 PM
jschira's Avatar
jschira
Fram filters are good enough, just not worth the premium price you pay. They aren't any between the Wally SuperTech but cost 1/2 again as much ($2 versus $3+).
I do like the grippy black rubber coating.
Old Apr 14, 2004 | 08:15 PM
78fordman's Avatar
78fordman
well, for the price there are better filters, but your motor will not explode if you use this one.
Old Apr 22, 2004 | 09:32 AM
FERacing66's Avatar
FERacing66
thanks its autally a fram fleetare not fleet guard.its on a psd.
Old Apr 22, 2004 | 08:29 PM
mustangsvt's Avatar
mustangsvt
fram is garbage, refer to my other post about your engine dieing FEracing
Old Apr 23, 2004 | 09:54 AM
oppy's Avatar
oppy
Actually, the fleetcare filter is pretty good, and about the same price as Purolator or Motorcraft. I have used all of them and (IMO) there is little, if any, difference between 'em.
Old Apr 25, 2004 | 07:25 AM
jschira's Avatar
jschira
Fram's are on sale at PepBoys. 2 for $6 with coupon. No restrictions listed on the coupon.
Coupon available at www.pepboys.com
Old Apr 27, 2004 | 07:19 PM
Jet Jock's Avatar
Jet Jock
Just a thought on filters. Bought a F1 w/302. Had a fresh oil change drove it home it ran 30 psi hot. Didn't think much about it went to get a fram and they were out. Ended up at the local auto part store got a Wix. Oil pressure now runs 38 hot. Castrol GTX 10/40 both times
Jet Jock
"I drive a 'girly' 302 because, when I want to go fast, I go to work"
