Carburetion ! Why My engine Does This?......
Old Apr 14, 2004 | 07:45 AM
cigarxtc's Avatar
cigarxtc
When the screw in carb fuel filter gets clogged the engine will start and idle with no problem. I can even gun it in neutral or parked and the engine does not miss a beat. But when I put her in gear and give her gas she'll bog down or sputter and sometimes die. When it happens I just change the fuel filter and open the old one just to see what kind of crud is in it. I was just curious as to why, when the fuel filter is clogged, it would idle in neutral but when in gear it almost kills the motor? Does it have anything to do with the vacuum line from the manifold to the transmission? Or something else in the design of the stock 351m/c6 combo?
Old Apr 14, 2004 | 08:21 AM
73Custom's Avatar
73Custom
I would guess the filter allows just enough fuel through to keep it idling. In gear, the extra load or tip of the engine must be enough to kill it.
Marty
Old Apr 14, 2004 | 08:43 AM
biggreen78's Avatar
biggreen78
i have the same vehicle and problem i have notice that there are 2 hoses in the same fitting not connected to anything-1 is attatched to the air filter, and the other im not sure (im at work and can't look right now) they are just hanging there. i think its part of the emmissions equipment could this be related to the sputtering?
Old Apr 14, 2004 | 09:22 AM
cigarxtc's Avatar
cigarxtc
Marty, That's what I thought at first also, but when idling I can gun the engine to red line with no problem. That means a substantial amount of fuel is getting to the carb in neutral. That theory might not fit.
biggreen78, I don't have the EGR emmissions stuff and all hoses or vacuum plugs are present and accounted for.
My trucks runs great. I'm just perplexed as to why the clogged fuel filter causes my truck to do that? I'm just one of those people that likes to know how things work and what makes things tick.
Old Apr 14, 2004 | 10:33 AM
beartracks's Avatar
beartracks
It takes a lot more fuel to rev in gear. Power circuits open plus the back two barrels on a 4v. If your filter is clogging all the time you should consider dropping the tank and checking/flushing it and the lines. Original fuel lines/pumps are somewhat marginal to start with.
Old Apr 18, 2004 | 02:29 PM
Polkat's Avatar
Polkat
Beartracks has it. When theres no load on the engine, the only work it is doing is spinning itself, and it can do this at surprisingly lean mixtures. Sounds to me that you should think about why that filter gets clogged so often. Problem in the tank?
Old Apr 18, 2004 | 05:59 PM
pops_91710's Avatar
pops_91710
Polkat,
You are right on. Several years ago I had the same problem. The dinky fuel strainer at the carburetor's fuel inlet constantly loaded up with tiny reflective metallic particles. To this day I do not know what it was, but it was a cinch it was some type of contamination from the tanks. I simply added an inline filter closer to the fuel tanks and gutted the little strainer at the carb several months later to insure the problem wasn't mid-stream. The truck is still running today and I change the filter every three years. Never had a lick of problems since.
Old Apr 19, 2004 | 07:52 AM
cigarxtc's Avatar
cigarxtc
Thanks fellas. Ya, the fuel lines need to be replaced. I've just been putting it off. Guess when school lets out that I'll be replacing the rusted 3/8" lines with some 3/8" aluminum fuel line soon. I'm sure the tank could use a protective coating inside to help this issue also. But that will have to wait.
Old Apr 19, 2004 | 11:19 AM
biggreen78's Avatar
biggreen78
im sorry to intrude again, but do those gas tank additives work as a temporary fix? they have claims of stopping leaks and cleaning up the tank
thechainsawman
Nov 15, 2016 08:13 AM
mdecorso
May 4, 2016 03:44 AM
charecter1
May 28, 2014 07:07 AM
gildardo01
Feb 1, 2013 11:40 AM
