transmission swap question
Old Apr 13, 2004 | 04:34 PM
Psycho_bob_1977's Avatar
Psycho_bob_1977
Arrow transmission swap question
i have a 78 f250 4x4 with a 400 ( No M) and a C6.
i have a 77 f350 2wd with a 351m and a 4 speed tranny. i will be swapping cabs because the 350 has a better one. and it makes turning the truck into a 4 speed easyer. i've always wanted a 4 speed.
but here is my problem. the truck, being a 78 does not have a divorced transfer case. how can i mate this transmission to this transfer case? is there an easyway to do this? like an adapter plate? and where would i get one? or could i just weld a plate on the end of the tranny and put holes in that? or should i move the t case back and put a small driveshaft, like the highboy trucks have? basically turning it into a divorced t-case. the only problem i have with that is i dont want to lower the t-case like in the highboys. plus i want to keep it somewhat stock. has anyone done a similar swap to this? thanks for any help.
Old Apr 13, 2004 | 05:29 PM
CO4x4SD's Avatar
CO4x4SD
Assuming the 2wd and 4wd four speeds are the same (T18, NP435) all you would need to find is the factory adaptor to mate to the married NP205. I see them all the time on ebay. Or try a salvage yard.
Or....
http://broncograveyard.com/products/cat/18/96/21010
Or...
http://broncograveyard.com/products/cat/18/96/21012
Looks like two different lengths for some reason??? Either way there is a start.
Old Apr 13, 2004 | 05:33 PM
Psycho_bob_1977
im pretty sure the tranny is a np435. so thanks for the help. i'll look around on ebay and on those links. thanks for the help.
