Evaluating the 460's
Old Apr 13, 2004 | 02:05 PM
74' Ford F-100's Avatar
74' Ford F-100
Exclamation 460's 460's 460's!!!!!!
what year of fords 460 is the best. which year has the best heads and crank?
provide all info that you can!!!!!!
ford 4ever
Old Apr 13, 2004 | 02:15 PM
460f250's Avatar
460f250
Without any info at hand I'd say a '70 460. Pollution controls came in heavy after that and performance dropped. If I remember right some police cars came with 460's then, they'd be the one I'd look for.
Old Apr 13, 2004 | 02:21 PM
74' Ford F-100
thanks for you input. it is greatly appreciated. I need more specific information though!!!!!
Old Apr 13, 2004 | 03:38 PM
74' Ford F-100
Exclamation what is the best year for the 460?
i need to know which year was the strongest/higest performance.
Old Apr 13, 2004 | 04:00 PM
Big Orn's Avatar
Big Orn
Whoop! https://www.ford-trucks.com/forums/s...d.php?t=229477
Old Apr 13, 2004 | 04:36 PM
Mil1ion's Avatar
Mil1ion
https://www.ford-trucks.com/forums/s...d.php?t=229258
Old Apr 13, 2004 | 07:00 PM
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
Block ID #'s and what differs...
There are thick web and thin web blocks, as well as some blocks that can go .120 over and some that barely squeek by to .060 over. Ultrasonic "Sonic" testing is the best way to verify the safe bore capability of a block.
Thick web refers to a portion of the main web where the cap attaches. The thicker ones are D0VE-A 2 and 4 bolt, D1VE-6010-AA 2 and 4 bolt. These blocks are thick all the way [from where the main bolts attach] to the pan rail. These thin web blocks are C8VE, C9VE, D1VE (sometimes no suffix), D3VE and so on. These blocks neck down from the cap register to the pan rail. They need a splayed cap with a 3/8 bolt or a CJ vertical bolt.
Take a look here to get pictures and descriptions of the various 460 blocks.
FORDIFIED RACING
Old Apr 13, 2004 | 07:47 PM
74' Ford F-100
im looking for more of a specific year. i dont know if all the mounts on the block are the same throught the years but if it is different that may be a problem. im trying to mount it in my 74' f-100 and then back it with a C6 i need to know if any one year has a stronger crank or better flowing heads ect..... i appreciate the info on the block i will keep that in mind.
Old Apr 13, 2004 | 07:51 PM
74' Ford F-100
sorry..... so can anyone help me out.... i need to know if any year is more preferred due to a stronger crank, better flowing heads, ect...... thanks
Old Apr 13, 2004 | 07:57 PM
Mil1ion's Avatar
Mil1ion
Please read this.
Old Apr 14, 2004 | 07:34 AM
fordtrkpuller
FTE *******
Cranks are all the same
Blocks are basicly all the same aside from web thickness, rail thickness, bore-ability, 2-bolt or 4-bolt.
c8, c9, do, and d3 heads are considered best factory iron, the exception to this is the DOOE-R (the SCJ). The SCJ head has a larger intake port. The SCJ also has one of the (as cast) screwed up exhaust ports. The SCJ head can be ported to support about 670 hp, the others mentioned can be ported to support approx 600.
All blocks have the same mount boss.
All of this information is widly spread around this and other forums, as well as much more! Learn how to use the search function rather than standing in place yelling that you need more info.
78BroncoMP
1978 - 1996 Big Bronco
Oct 15, 2009 06:00 PM
YoungFordAddict66
Dec 22, 2008 11:24 PM
heep70
Feb 9, 2003 10:14 AM
FlowmasterMan
Exhaust Systems
Nov 26, 2001 06:45 PM
proud owner
Aug 31, 2001 10:31 PM
