1996 Ford EXplorer
Old Apr 13, 2004 | 11:04 AM
jbranham's Avatar
jbranham
1996 Ford EXplorer
I just installed new brake pads front and rear on my 1996 Ford Explorer. I now feel a shake or front end vibration when I hit a bump in the road. The vibration causes the whole front end to vibrate. The vehicle has 121,000 miles and the tierod ends or ball joints have not been replaced. Any suggestions?
Old Apr 14, 2004 | 05:16 AM
marragtop's Avatar
marragtop
If you only did pads, I assume you didn't need to remove the rotors or bearings. It may sound stupid, but are you sure the wheels are on tight?
Old Apr 21, 2004 | 08:45 PM
Flyman's Avatar
Flyman
I also have a 96 Explorer. Mine only had 80,000 miles on it when it needed all new ball joints, they had almost 1/4" of play in them!
Did you have the rotors turned? Or new rotors?
It does sound silly.... But like the last reply, it is very easy to get the aluminum wheels a little ****-eyed. Even a tire seller did this to me once......
Good luck, Dan
Old Apr 21, 2004 | 08:50 PM
jbranham's Avatar
jbranham
1996 Explorer
After I installed new rotors, no more vibrations.
