Sponsored by: Real Truck
Another lift ?
Old Apr 12, 2004 | 06:20 PM
nickdoni's Avatar
nickdoni
Another lift ?
Hello all.
I was wondering if any of you lift gurus think i would need a dropped pitman arm with a 4in lift?
Old Apr 12, 2004 | 07:28 PM
Badford's Avatar
Badford
yes, i would invest in one. anything to help keep the factory geometry.
Tony
Old Apr 12, 2004 | 09:12 PM
Yeti's Avatar
Yeti
I agree, it's worth it.
Old Apr 12, 2004 | 09:20 PM
lssnl's Avatar
lssnl
Just put a 4" lift with the 35's on my F-350. You really do need the drop. When I order the kit it is highly recomended.
Old Apr 12, 2004 | 10:12 PM
mattsf250's Avatar
mattsf250
ahhhhhhh!
even when you install an adjustable trac bar?
i know. whats one got to do with the other?.... i had a thread goin a while ago, and it seemed unanomous that if i used an adjustable trac bar, i did not need a pitman arm/drop bracket??
as i understood it, if you use a drop bracket, you use a drop pitman and vise-versa?
since my plans of installing my lift last weekend were foild by a bag-of-douche fedex employee, id like to know while i still have time to order.
please, clarify, AND DONT BE VAGUE!
pretend your explaining it to a total idiot (that would be me)
Old Apr 12, 2004 | 10:28 PM
Yeti's Avatar
Yeti
Originally Posted by mattsf250
ahhhhhhh!
2 TOTALY DIFFERENT THINGS!!
The pitman arm will correct any steering bind, due to rasing the steering box 4" from where it use to connect to the drag link. With out it, the angles are to severe.
The track bar keeps the axle from moving left or right.
The frame moves away from the axle when lifting, so you would need a drop trac bar bracket, or a adjustable trac bar, so your axle remains centered and not pulled to one side due to the factory trac bar being to short.
Make sence??
Old Apr 13, 2004 | 07:48 AM
mattsf250's Avatar
mattsf250
yep....
thank you.
Old Apr 13, 2004 | 06:29 PM
DCSpecial's Avatar
DCSpecial
Above 4" you need a pitman arm and trac bar bracket......you need to run both to keep proper steering geometry.
Under 4", with "leveling kits" a pitman arm isn't needed and therefore using a drop trac bar bracket would change the geometry of the trac bar in relation to the drag link. Since the drag link can simply be lengthened under 4" of lift and adjustable trac bar can be lengthened accordingly.
Old Apr 13, 2004 | 06:43 PM
TOPFLOR's Avatar
TOPFLOR
I am running 18" susp lift w/o any extra parts...just kidding..i am drunk and think i am actually funny. this is a veryinformative thread. keep the info coming gentlemen!
Old Apr 13, 2004 | 06:45 PM
RRMike's Avatar
RRMike
If the lift comes with a track bar bracket you should also get a drop pitman arm. If it does not you should get an adjustable track bar and leave the stock pitman arm on to keep the angles parallel.
Old Apr 13, 2004 | 07:01 PM
Donahoe's Avatar
Donahoe
Yes a pitman arm is proper.
Old Apr 13, 2004 | 07:48 PM
nickdoni's Avatar
nickdoni
Can i just heat up the factory pitman with a torch and bend it down?Im drunk as well and i thought i would keep the funnies going.Thanks for all the info thuogh.
Old Apr 13, 2004 | 08:40 PM
cwb's Avatar
cwb
I have a drop pitman arm for sale. But I am cahoots with Fedex so you may never get it. Matt, I filed the claim today. You should have your money in five to ten days.
Old Apr 13, 2004 | 08:54 PM
mattsf250's Avatar
mattsf250
lol!
me, my money> i thought you were gettin the fedex take forever money in 10-30 years?? :P
anyhoo, go check yer damned mail!
i need answers, and i need em yesterday!
ps, i am on my 3rd shot of straight rum in the last 7 minutes ( just got home) and none of you are funny!/
I am the only funny person here
Old Apr 13, 2004 | 10:27 PM
mattsf250's Avatar
mattsf250
dowe not have the technology to create a faq regarding suspension lifts for sd's ??????
holy hell this is a PITA!
i just want to know what is required, what is optional, and whats a waste of time!
