Yes, hubs are always unlocked except for when using the 4 wheel drive which has been maybe a total of 250 miles out of the 86k. Any need to change the fluid....if so....how do you do it?? I see no drain plug!
I wouldn't worry about changing it yet. I believe there is only 1 plug on the diff for fill and drain. The only way to truly drain it is to remove the cover.
Removing the cover seems like a pain...I opened the plug and the fluid looked like fresh oil yet(same color). Assuming it is pretty good yet. When would you look at changing it? Just to clarify for myself someone please explain what is happening in the front diff with hubs unlocked, hubs locked, and hubs locked with 4 wheel engaged. Can you truly use 4 wheel drive without hubs locked in? Just never really understood the whole system I guess. Thanks
I would change at 100K. It's not really that much of a pain to remove the differential cover. Make sure when you remove it you get some gasket maker for when you reinstall. I just recently changed my rear fluid and it didn't take long at all.
I just did the rear today with mag hytec pan! A whole lot easier!!! What is involved in resealing the cover????
You clean the mating surfaces and put the gasket maker on one of the surfaces making sure to surround the holes. Reinstall, tighten, refill, and you're done.
hubs unlocked- wheel spins free, your diff and u-joints and front drive shaft should not turn.
hubs locked- front diff, u-joints and drive shaft will turn, but the system is still disconnected at the transfer case
hubs locked and 4x4 engaged- the whole system is engaged including the transfer case and you have a 4x4.
This is how it works on my 97' hope it helps. It is also not recommended to run with your transfer case engaged and hubs unlocked, although I forget why. It is however ok to run with the hubs locked and tranfer case not engaged, I just wouldn't do it for long periods of time and not on a highway.
So this being said.....with the hubs unlocked is there really any reason to ever change your front diff fluid since it is only used maybe a 1000 miles or less during the life of the truck for most people??
If you ever get in water as deep as the hubs or deeper - yes. Otherwise as long as you can check it through the fill hole and it looks ok - probably not. Personally I will do mine whenever I do the rear 'cause I leave my hubs locked in most of the winter, unless I'm taking a long trip, just so I'm ready.
