High idle
Old Apr 12, 2004 | 12:15 PM
MustangGT221's Avatar
MustangGT221
High idle
Hey guys,
Having a slight idling issue. My truck will idle around 1500 rpm and not come down. I just installed a FMS MAF conversion kit and have not yet changed the firing order on the injectors. It runs fine, just not SEFI. When I did the swap, it was running fine and the idle was ok. That was about 2 weeks ago maybe. My spider/side gears went out and the truck spent about a week and 1/2..maybe 2 weeks sitting in the driveway until I could repair it. Got everything going and last night I test drove it. Now my idle is pegged on 1500 and won't go down on its own. Now I do throw a check engine light, but it's been doing that since I put the MAF kit in because of the injector order. So basically, everything was working ok after the MAF swap, but now its been sitting for a week or two and the idle is screwy. Any ideas?
Old Apr 12, 2004 | 12:51 PM
guzzler96's Avatar
guzzler96
Arrow High Idle
Don't know how your engine is set up, but I have had (2) different occurrences of high idle caused by (2) different things. My '90 302 has all the emmissions control stuff on it. TAD, TAB, EGR EVR solenoids, smog pump and the whole nine yards. First high idle was the vacuum line coming off the bottom of the air bypass valve down by the smog pump. Second high idle was an Upper Intake Manifold gasket leak. First time idled at about 1100 and would not come down. Second time idled at about 2200 and would come down. First fix was easy, just put the line back on. Second one, had to install new gasket. The link below was posted on the 5 th, called High Idle Possible TPS? and I think it turned out to be intake gasket too.
Let us know,
guzzler96
https://www.ford-trucks.com/forums/s...d.php?t=225645 on manifold.
Old Apr 12, 2004 | 01:05 PM
LoosMaster's Avatar
LoosMaster
This might be a stupid ? Justin. Though you're throwing a check engine light for the injector order, have you run a code check again? You can get more than one code.
Old Apr 12, 2004 | 05:02 PM
MustangGT221
Thanks for the advise guys, but for some reason its fine now. Funny cuz right after I made this post I went out and it was fine....weird.
Old Apr 12, 2004 | 06:10 PM
EPNCSU2006's Avatar
EPNCSU2006
I see the problem was resolved, but what code is it throwing with the MAF computer?
Old Apr 12, 2004 | 07:32 PM
Talyn's Avatar
Talyn
TPS had a hickup.
Old Apr 12, 2004 | 09:07 PM
MustangGT221
Havn't checked it yet, but after the rain over the next few days i'll check.
Old Apr 15, 2004 | 08:10 PM
mike_2000's Avatar
mike_2000
I've had a high idle problem for a while. I checked for a vaccum leak and didn't find anything. I was looking it over today and found out that the "coffee can" loacted on the pass side fender under the hood, had a small rust out hole on the bottom. There is 2 vaccum lines going into it. I pulled one vaccum line and I had vaccum going into the "coffee can" but nothing going out. Then I found the hole in the under side of the "coffee can". Now the truck runs fine.
Old Apr 15, 2004 | 08:33 PM
fordberg's Avatar
fordberg
If the problem is solved then can I ask. This FMS MAF thing. Is this some cam change or what to change the firing order? Maybe a link to the site. You got me confused.
Old Apr 15, 2004 | 08:58 PM
MustangGT221
Do a search on MAF conversion
Old Apr 17, 2004 | 09:27 PM
tomjohnson150's Avatar
tomjohnson150
Looking for air tubes to throttle body
This is for mustanggt221, i was looking at the pics of your spark plug wires and noticed your air tubes going to the throttle body...where did you get these? i want a set of smooth ones so i can wrap thermal barrier tape around them and the airbox, but the set of tubes i have now are the stock ribbed ones...
Old Apr 18, 2004 | 12:14 AM
MustangGT221
They came in my MAF kit, but they are similar to the ones off an 87-91 or so truck.
Old Apr 18, 2004 | 07:40 AM
jroehl's Avatar
jroehl
It would appear that way. My '90 302 F150 has smooth ones. My '93 351 F250 has the ribbed ones.
Jason
MarksA-C
2004 - 2008 F150
Apr 20, 2014 08:37 PM
fiftyfordfloored
1997 - 2003 F150
Feb 5, 2013 01:57 PM
Reed
27
Apr 29, 2012 08:56 AM
Reed
Jun 21, 2010 09:38 PM
phreaky
Modular V10 (6.8l)
Sep 9, 2008 11:48 AM
