supertuner or diablo
Old Nov 28, 2002 | 03:02 PM
Gutlassf250's Avatar
Gutlassf250
Old Dec 2, 2002 | 05:04 PM
Mizzou's Avatar
Mizzou
what is the preferred or best programmer for a psd (1999) I am going to purchase one asap and would like some additional info. I have a 5.5 inch lift with 35 X 12.5 X 16.5 in addition to the power boost the speed correction is the main thing. An increase in mpg is a bonus but not the main reason I want it
Old Dec 2, 2002 | 05:40 PM
Quadzilla's Avatar
Quadzilla
First, let me say that I'm absolutely **** about mpg. When I got my Diablo Delta flip chip, I had one program installed that was intended to increase mpg. What I found was the the truck ran better, was much more driveable since the shift points were better placed, and it was generally more fun to drive, but the mpg didn't change. It didn't go up or down, so getting a chip for mpg gains would have left me disappointed. After running four different power levels of the same code, TDE0, that my mpg doesn't vary more than .5mpg regardless of program I run. I personally like the idea of being able to shift on the fly between programs, but guys that have programmers love them for the simplicity. There are pros and cons to both systems, and your personal preference will help you decide. This message board has a section entirely devoted to chips. Pour yourself a cold one, and start reading there. Good stuff.
Quadzilla
'95 F-350XLT Crew Cab SRW 4X4 PSD, 35X12.50X16.5's, Limited slip 4.10's, Hypermax downpipe, gutted EBPV, "Catless" in Seattle, "Renegade" 4" exhaust system, CTFD sticker, Air bags on all four corners, TYMAR intake, shimmed fpr, Diablo Delta chip, Fumoto valve, Autometer pyrometer, Sonnax valve, Tricumulator springs, Tru-Cool, HX mod, Magnefine tranny filter,
4R100 pan, Red Line synthetic in transfer case and both diffs, reverse shackle kit.
And a wish list that gets longer every day.
(Thank God for a wife that likes big trucks.)
For pictures, click here: http://community.webshots.com/user/quadzilla100
Old Dec 2, 2002 | 06:47 PM
FTE Ken's Avatar
FTE Ken
If you can get diesel fuel with a c-tane rating of 45 or better you should get a significant mpg increase with the chip. Problem is most stations don't put the rating on the pumps because unlike gasoline they aren't required to. Give that a try and let us know.
Old Dec 3, 2002 | 09:35 AM
bricot's Avatar
bricot
I would have got the flip chip but they didn't make one for my year/model, so I went with the super tuner - not disappointed, EASY to use no installation, but you can't switch on the fly...
