Smoking during warmup!
1997 F 250PSD 4X4 SC Longbed No mods that I know of.
I know, blue smoke indicates in most cases oil is burning but
have you ever checked your glowsystem? Maybe you have a bad glowplug.
If your glowsystem is ok....hm....are all gaskets at your turbo in good condition? It could be possible that some oil comes thru the turbo into your cold engine, that a maybe a reson for the oil in your inlet tube.
Hope thats helps.....
Jens
2001 F-350 CC Lariat 4X4 LB PSD SRW, Heated leather, off road package, western snow plow, strobe lights in parking lights, headlights and backup lights, tinted windows, stull billet insert, pioneer cd player, rockford fosgate 700S amp rocking 3 JL Audio 10W0's behind back seat,Infinity Interiors and an Alpine amp, husky liners front and back,Banks transcommand, K&N FIPK, ATS Ported Turbo Housing, Diablo Sport 110HP chip, Hypermax pryo/boost gauge, Hypermax 3.5 inch downpipe and 5 inch exhaust.
2002 F-350 XL 4X4 PSD DRW, XL Decor Package, 9' Heil Dump Body, 8' Western (for now) Poly Plow, Strobes Front and Back, toolboxes and Wheel Simulators.
There is a 7 mile grade at 7% here in Colorado and when I drop off of it with the PSD in the winter, I'll get loads of blue smoke and it rattles like crazy at the bottom when I first start putting fuel to it. It does this because of the huge volume of cold air that has passed through the engine with no fuel to burn. Once the combustion chambers warm up, everything returns to normal.
>on it, my 2001 with 29,000 on it...never did it from new.
>Should this be of concern?
Distinctive Dave....talk about weird!!! No, not you man, this blue smoke thing. I went to post a thread asking the same question this morning. Yesterday I leaned into the passenger door to start my PSD and looked at the tail pipe and noticed a huff of blue smoke. I looked like a dog listening to a harmonica! Figured I would shout at everybody at FTE to see whats up. I guess alanscott answered my question. It has been cold in the mornings....at least cold by Florida standards.....40*+/-. Well anyway, I am glad it is a "normal" condition. OK the boat's warmed up.....I'm going fishin'
Quadzilla
'95 F-350XLT Crew Cab SRW 4X4 PSD, 35X12.50X16.5's, Limited slip 4.10's, Hypermax downpipe, gutted EBPV, "Catless" in Seattle, "Renegade" 4" exhaust system, CTFD sticker, Air bags on all four corners, TYMAR intake, shimmed fpr, Diablo Delta chip, Fumoto valve, Autometer pyrometer, Sonnax valve, Tricumulator springs, Tru-Cool, HX mod, Magnefine tranny filter,
4R100 pan, Red Line synthetic in transfer case and both diffs, reverse shackle kit.
And a wish list that gets longer every day.
(Thank God for a wife that likes big trucks.)
For pictures, click here: http://community.webshots.com/user/quadzilla100
>cold combustion chambers and is normal. The colder it is,
>the more noticible it will be.
Absolutely, that's normal at start up for sure, but beware of this:
At temperatures below 0° F., and at high altitudes(high altitudes are more common for this), diesels will suffer from a condition known as "flame out". This is when the ambient temperature is so cold that it literally puts the flame front out in the combustion chamber. It's a very wierd phenomenon, because the engine is at normal operating temperature, but it acts like a cold engine. It's also potentially serious in that fuel must never touch the pistons. Diesels fire with a cushion of air between the flame front, and the piston. If this is disturbed, it may wash the cylinders, and cause scored pistons/liners, and damage the rings.
Could this hill be Eisenhower? Or Vail Pass?
you are right on alanscott.
I have experienced the same thing. That's what reminded me to mention the above. Newer diesels such as the PSD are not as much at risk because of their higher injection pressures, turbo improvements, and their overall efficency over the old engines. Best way to cure this (If you should ever experience it) is to simply try to get warmer intake temperatures. Cover your intake, or try to open your intake plumbing (before the filter housing of course) so that you draw in warmer air from under the hood until you reach warmer and denser air.
This is why so many big rigs spec'ed to work in cold climates have inside/outside air selectors on their air filter housings, so they can switch them to pull warm air from under the hood.
Sorry for the essay.
Your post just made me think of this.:7 97 F250 PSD 4x4 SC:-X12 :-X12
US 40, Rabbit Ears Pass just outside of Steamboat Springs, Co.
Eisenhower would probably do the same thing except I hardly ever drive it. I always go over the top out of habit
I have never had it happen on Vail, I think it's because of the shelf on the west side were a little throttle is used to maintain speed.
