spark plug gap
Old Apr 11, 2004 | 09:10 PM
jitter1976's Avatar
jitter1976
Unhappy spark plug gap
i have a 1978 F150 4x4 with a 351w new plugs new wires new distributor and rotor but the place that put them on said they had to reset the gap but now it idles perfect but cuts out and backfires at about 2000 rpms but only when in gear and moving it does not do that when sitting still at 2000 rpm could they have gapped the plugs wrong any help would be greatly appreciated oh and weve checked the timing and seems fine
Old Apr 11, 2004 | 10:12 PM
Mil1ion's Avatar
Mil1ion
I bet that is a 351M not a Windsor.
The gap is probably .044"
You can ask this in the 351 engine series forum as it is not 73-79 Truck specific
Old Apr 11, 2004 | 11:34 PM
Matts72's Avatar
Matts72
yeah, 302, 351W,C,M, 400, 429, 460 all have a .044" gap
Old Apr 12, 2004 | 09:42 AM
beartracks's Avatar
beartracks
Sounds like they messed up a plug or wire.
Old Apr 12, 2004 | 03:34 PM
bobs75f-250's Avatar
bobs75f-250
What's the gap for a 360? Is it .038"? I'm having a very similar problem.
Old Apr 12, 2004 | 05:27 PM
corv_66's Avatar
corv_66
Have you checked the vacuum advance? Also, does it backfire when you step on the throttle at all rpms, or does it only do it at 2000 rpm? Because it sounds like a vacuum or carberation problem.
Old Apr 12, 2004 | 08:10 PM
Hardball's Avatar
Hardball
Sounds like either, carb, fuel filter, fuel pump, or maybe it is arcing somewhere. Timing is probably still a possibility also.
Old Apr 13, 2004 | 10:32 PM
robertdale's Avatar
robertdale
the gapping set should be on a sticker on the inside of your hood on the driver side.
