Better brakes available?
Old Apr 11, 2004 | 06:59 PM
subcoolman's Avatar
subcoolman
I was alerted to this site from the local Ford parts guy, and this is my first post here, so please bear with me!
I have a '92 F150, 351, x-cab, 8 ft. box, with HD springs. Truck pulls my boat great, but rides like a 3/4 ton. I completely rebuilt the front-end, and now I'm looking to upgrade my brakes as they are kinda wimpy. I can't seem to stop quick enough, at least not to my liking, and with the boat attached things get even worse. I'm having difficulties finding a supplier for aftermarket brake kits/systems. Specifically, I'd like to either replace my pads, rotors, drums, and shoes with "stickier" stuff, or maybe replace everything with a complete (larger?) system.
I contacted Baer brakes about helping me out with this, but haven't heard anything from them.
Anybody have any ideas?
Thanks for any and all help/advice.
Jim
Old Apr 11, 2004 | 09:43 PM
LoosMaster's Avatar
LoosMaster
Don't know how much you want to spend, but good products and service.
http://broncograveyard.com/products/...Submit=+Go%21+
Old Apr 11, 2004 | 09:55 PM
subcoolman's Avatar
subcoolman
I'll spend whatever it takes to put the "whoa" into this heavy thing!
Thanks for the site- I'll check it out!
JIm
Old Apr 11, 2004 | 10:41 PM
ATC_250SX's Avatar
ATC_250SX
What about putting brakes on the boat? maby its to big to tow with the heavy half ton.
Old Apr 11, 2004 | 10:48 PM
Saurian's Avatar
Saurian
I believe you can go out and get the late-model old-style explorer rear ends complete with their large-diameter disc brakes that are direct replacement and offer superior stopping power.
Old Apr 11, 2004 | 11:02 PM
subcoolman's Avatar
subcoolman
The boat is an aluminum 18' Lund ProV, but I forgot the weight. The trailer has hydraulic surge brakes, so that helps a little. My biggest complaint is the stock Ford brakes on this heavy a vehicle don't cut it, and I can't slow this pig down fast enough in an emergency. Heck, I can't even lock the tires if I tried, and I replaced the calipers, master cyl, etc. when I rebuilt the front end. Now, the brakes work as intended, I'm sure of that, but I've had sweaty palms more times that I'd care to remember, and that's without the boat attached. I really feel for those OTR truckers when people pull right in front of them.
Ultimately I'd like to get better rotors, pads, rear discs, the works, but I can't find any. Cost is one issue, but not as much of a consideration as safety right now.
Old Apr 11, 2004 | 11:08 PM
Saurian's Avatar
Saurian
Never had trouble finding parts for MN-12's....but I suppose that's a quasi-sports car.
Go onto 4-wheeling sites. Or bust open some pages of 4-wheeler magazine
I believe they did a story on brakes a while back..and on upgrading them *shrugs*.
Old Apr 11, 2004 | 11:15 PM
LoosMaster's Avatar
LoosMaster
I think that might be Ford's fine ABS system working at peak performance.
Old Apr 11, 2004 | 11:24 PM
subcoolman's Avatar
subcoolman
LOL!
Sad, but true!
Old Apr 11, 2004 | 11:29 PM
LoosMaster's Avatar
LoosMaster
I don't know if I should tell you this or even recommend it. Pull the plug on the brake controller and see if that helps.
Old Apr 12, 2004 | 11:37 AM
jimandmandy's Avatar
jimandmandy
There are plenty of high performance upgrade pads and rotors available without going to expensive oversize ones that will not fit inside stock rims. EBC Greenstuff, Hawk, Performance Friction, Rabestos ceramic, Brembo rotors and the list goes on. One thing you need to do first is flush out that old brake fluid and maybe an inexpensive upgrade to DOT 4 fluid. That alone helped me out. The fluid must have been boiling in the calipers when I felt the brakes go "soft" on a steep grade last summer.
Jim
Old Apr 12, 2004 | 12:11 PM
FordPerf300's Avatar
FordPerf300
F350 Master Cylinder, high quality slotted rotors and pads that are designed for them. Not totally sure on this but i hear thunderbird calipers (not sure on year) are dual piston and supposedly fit on 78/79 broncos, i say that becasue i know for a fact that 80-96 F150/bronco calipers also fit on 78/79 brackets so the tbird calipers might also fit on 80-96 f150... just some thoughts
Old Apr 12, 2004 | 02:20 PM
faroffthetrack's Avatar
faroffthetrack
The best thing to do if you want to slow down quicker is disk brakes on the bake and larger rotor size.
Old Apr 12, 2004 | 02:23 PM
faroffthetrack
back* I mean
Old Apr 12, 2004 | 06:41 PM
fordberg's Avatar
fordberg
Nothing worse than brake problems. Don't know if you have a problem but my 95 F-250 has brakes that are very good. I think we need to hear from people with the same rig, model, year. Try to identify if it's the rig or the design.
