Straight pipe?
Old Apr 11, 2004 | 11:33 AM
Hossy's Avatar
Hossy
Straight pipe?
Hey guys, I bought my 01 f350 used, and the dealer had the local exhaust shop put on a generic 3" muffler on. My guess is it had a straight pipe on it, in MO. you need a muffler to pass state inspection. I cant afford the exhaust i want right now, Would i notice a difference if i had the muffler cut out and a straight put in? The rest of the exhaust is stock. Thanks guys.
Old Apr 11, 2004 | 12:17 PM
BigBully's Avatar
BigBully
a 3 inch or 3 1/2? What kind of Muffler? Does the pipe go in and out in the same positon or does one go in Low and one come out High? If its the same then its a straight through Muffler and you wont see much if any gain by taking it off. If its an Offset In/Out then you should gain taking it off.
Old Apr 11, 2004 | 12:31 PM
johnsdiesel's Avatar
johnsdiesel
I agree with BigBully. Do you really need a muffler in a diesel to pass the state inspection? There are usually different rules for diesels and the turbo actually acts as a muffler. Regardless, you can get a performance muffler for your system that would help out. Stock system is 3.5" on your truck I believe. You will see some gain by removing the muffler, especially if it's a generic offset not designed for your application.
Old Apr 11, 2004 | 12:58 PM
FERacing66's Avatar
FERacing66
can you get headers for a PSD?
Old Apr 11, 2004 | 04:06 PM
Hossy's Avatar
Hossy
I'm a mo state inspector so either way it will pass now. But in mo it has to have a
muffler, however it doesnt have to pass any emissions sniff test. And yes it is a 3", i
measured it, none of the muffler shops in stlouis county handle anything over 3",
I know because i called around, gotta go a few miles away to get to where they can cut and bend bigger. The muffler is oval and offset like something from midas. And a very poor weld job to fill in the joints. Thats what has me so concerned, Thanks JD and BB. hossy,.
Old Apr 11, 2004 | 05:37 PM
CAT_man_963's Avatar
CAT_man_963
Yea if it's 3" scrap that thing and get a straight through muffler made for a diesel. If you're gonna get a full exhaust later then just get something to work for now and save the cash for later!
Old Apr 11, 2004 | 07:12 PM
johnsdiesel
I read somewhere that some company is going to start selling them but you really don't need them. Not the same as a gas engine. If you want performance concentrate on the turbo back. A larger downpipe and 4" exhaust is good to about 450 HP.
Old Apr 11, 2004 | 09:04 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I would tend to disagree. I think in this instance it is exactly the same as a gas engine, just for a different reason. We put headers on our gasers to expel more exhaust at a faster rate. On a PSD that should translate into more boost sooner.
Purely speculation here, but I think the lack of aftermarket headers for the PSD would have more to do with packaging than anything else. There simply isn't very much room between the engine and the fenderwell, plus look at the angle of the exhaust manifolds......lots of custom bending to be done to fit headers. Maybe too much to make it cost effective to produce.
Then there's the up pipes...not much point in high zoot custom headers without matching custom sized up pipes. That would be akin to putting a 4" exhaust on with a stock muffler.
Of course I totally agree that a 4" turbo back system is more than enough to handle everything we can muster so far, I just think there is definately room for improvement on the other side of the turbo too.
Old Apr 11, 2004 | 09:15 PM
cookie88's Avatar
cookie88
FTE Emeritus
The stock exhaust is 3.5", so if someone put a 3" muffler on without reducers it would explain the sloppy fill weld, must look terrible. Also a baffled muffler is a restriction on a turbocharged vehicle. You will be much better off with a muffler of a straight through design. You can get a straight through truck muffler at NAPA then just have it welded in, shouldn't be any bending required.
Old Apr 11, 2004 | 10:30 PM
96ford4x4turbodiesel's Avatar
or you could just gut it and have straight pipes with the muffler still on
Old Apr 12, 2004 | 08:25 AM
Hossy's Avatar
Hossy
Thanks for all your help guys. Going to get a straight pipe today.
Old Apr 12, 2004 | 10:31 AM
majorpecs's Avatar
majorpecs
here's my observations: I had the stock exhaust on a 2000 7.3l 4x4 and we pulled the muffler and everything behind it off. The stock system once made into a straight pipe application was awesome. Saturday I removed stock totally and put in a 4" turbo back system with a straight through muffler. Turbo whine is almost gone, exhaust sounds like stock, and I could sware I seem to have lost some horsepower. I believe I am going to pull this muffler off and stay with a 4" straight pipe with a turndown now. My truck seemed to like the "no restriction at all" application better than the new system. By the way, does anyone know if it's legal or not to have a straight pipe in Texas on a diesel engine?
Old Apr 12, 2004 | 11:57 AM
johnsdiesel
OK, but don't you think it's strange that they aren't available if they will give some performance gain? I would think some aftermarket company would be mass producing them if that was the case. Would the turbo spin too fast?
Old Apr 12, 2004 | 02:37 PM
I think it depends on what county your in.
Old Apr 12, 2004 | 02:44 PM
majorpecs's Avatar
majorpecs
Texas is in the USA
