Tire Size????
Old Apr 10, 2004 | 11:01 PM
grapplechamp's Avatar
grapplechamp
Tire Size????
Can i put 35's on my ranger??? Will the axles be able to handle the bigger tires or would i have to put full size axles on it? Thanks for your help
Old Apr 11, 2004 | 01:58 AM
98xlt4x4's Avatar
98xlt4x4
Need more info. What year, engine, tranny, 4x2 or 4x4? If the truck has an 8.8" rearend it should be fine.
Old Apr 11, 2004 | 10:09 AM
Waves's Avatar
Waves
As 98xlt4x4 said, if you have the 8.8" rear end, it can handle it. If you have the 7.5" rear end, as I understand it, anything bigger than 33"'s tall, you start snapping axles. There are many available suspension lift's, that in combination with a body lift, will enable you to be able to clear 35's - no matter what year 2x or 4x. It's expensive, but it can be done. Give us the specs on your ranger and I (as well as many others on this board) can give you a little more specific info on what it will take.
Waves
