Auxillaury idle controller
Old Apr 10, 2004 | 09:12 PM
powerstroked162's Avatar
powerstroked162
ok, what does this AIC do for a '96 PSD auto? worth it? what will i gain if i decide to make the mod? any problems that could occur in the future?
Old Apr 10, 2004 | 09:19 PM
johnsdiesel's Avatar
johnsdiesel
It allows you to raise the idle speed of your vehicle. It's a nice feature if you live in a cold climate and start your truck to "warm up" in the winter. An idling diesel will never really warm up, but this prevents wet stacking (fuel getting into the oil).
You're a busy guy with all these mods! Just trying to figure out what to do first?
Here's a link on the how to if you want to do it:
https://www.ford-trucks.com/contents...e%20Controller
Old Apr 10, 2004 | 11:24 PM
little rowe boat's Avatar
little rowe boat
Thumbs up
When I ordered my truck I purchased the aux idle control. I love it.I tow my boat across the desert during the summer and when i pull into Parker AZ. I fill the boat up and with my dog in the truck I idle it up to about 1500 rpm and leave the a/c on, when i get back into the truck it's nice and cool inside and the dog is not drooling all over the interior.
Old Apr 10, 2004 | 11:36 PM
powerstroked162
so the AIC basically works just like someone sitting in the truck with their foot on the throttle, am i correct? how big of range is there to adjust from( rpm wise )? what should a guy keep it at? do you have to shut it off when your driving? what happens if you leave it on while driving?
Old Apr 10, 2004 | 11:41 PM
johnsdiesel
Yes, it works like someone holding down the accelerator. You shouldn't have it on when driving. You adjust the rpm depending on the situation. In cold weather you would want to have it turned up higher than warm if you're trying to keep EGT's up to prevent wet stacking. If you're running an accessory like A/C adjust until you get the desired power. I have no idea what would happen if you left it on when driving.
Old Apr 10, 2004 | 11:46 PM
little rowe boat
You can not leave it on when driving,that is not how it is set up. The parking brake must be set in order to use the Aux idle control.
Old Apr 10, 2004 | 11:48 PM
johnsdiesel
lrb, the link I gave was for a homemade setup and I'm not sure you have to have the parking brake on with it. Do you have the Ford AIC or did you get another unit?
Old Apr 10, 2004 | 11:49 PM
little rowe boat
I ordered it through Ford.
Old Apr 10, 2004 | 11:53 PM
johnsdiesel
Do you mind sharing how much you payed for it?
Old Apr 10, 2004 | 11:54 PM
powerstroked162
so when you turn off the switch does everything go back to the way it was before the instal of the AIC?
Old Apr 10, 2004 | 11:58 PM
johnsdiesel
Yes. (that answered the question buy I apparently need to type at least 10 characters in order to post )
Old Apr 11, 2004 | 12:02 AM
little rowe boat
Back in 2000 when I ordered the truck,it was an option that I wanted,and I believe I paid about $200.00 for it. It has a bracket that mounts under the dash and plugs right in.Very easy to install.
