i've been running fuel injector cleaner with 94 octane. i'm honestly intimidated by the fuel injectors. not sure what i'm opening up. i've read that when they quit, they usually get stuck open which would flood the engine. doesn't appear to be the case, but anything is possible. next nice day, codes are first priority.
Replace the coil. You didn't say how many miles did you? Did your timing set jump a tooth? Try the O2 sensor, get one from the dealership the cheap ones suck.
low92flareside. I am not talking about the stuff you put in the gas tank. I am talking about the type you run into the fuel rail and run the engine off of for about 10 minutes. The stuff you add to the fuel tank is pretty useless if you have or develop problems. I have tried it before, but still ended up with dirty injectors. The fuel rail cleaner was run through and it was like a new engine, no miss and much more power. I's not certain that's your problem, but if it has never been done before on you vehicle, it will certainly help. I am determined now to make it a maintenance issue with my vehicles now. I will have it done every 40 to 50k.
One thing you can also check is the temperature sending unit for the ecm. On my 93 302 it was mounted on top of the thermostat housing in a tee fitting with one of the heater hoses. My problem was that the truck was running rich all of the time. in my climers manual it gave the resistances for the temp sender and mine read when the engine was warmed up the value for 120 degrees. I spliced into the wiring harness to the sender and put a resistor in the plug that had the value for 194 degrees and test ran the truck. it was hard starting when it was cold and ran like you described until it was warmed up. maybe you have a sending unit that is telling the ecm that your engine is way warmer than it really is. worth a try.
The last thing you hope to go wrong, In tank pump, and The last thing you want to replace in the driveway.......
That was one of the things i checked on mine when it was acting up..
I took off the fuel lines going to the resivior then had a friend crank her over to see if fuel was comming out.....but whats to say that going to tell me the awnswer....
From what I gather the pump in the tank just delivers fuel and the other pump builds fuel pressure ........
wasn't too terrible. floor jack did the job. and yes, the in tank pump throws fuel at an arbitrary rate. next pump inline builds pressure to the system allowing fuel to travel to fuel pressure regulator which then slows it back down to a rate the fuel injectors can handle.
