Sponsored by: Auxito
Brake pad choices....
Old Apr 10, 2004 | 12:13 PM
01' Super Crew's Avatar
01' Super Crew
Question Brake pad choices....
I'm about to change the rear rotors & pads on my Supercrew. Has anyone had good results(low dust, no noise, good stopping power) from a certain brand of pads? I really don't want to get into directional cross drilled rotors or racing pads. I'm looking at Napa's "Ceramix" pads (Rabestos), Performance Friction products and O.E rear pads. I have a connection at a dealer to get really good prices on OE parts. The OE rear rotors happen to be the best priced ones I've found yet but the pads are severly overpriced. I had Napa rotors & "Extreme duty" pads on the front since last August when my truck failed inspection due to too much rust on the front rotors. The Napa clerk told me that "Extreme duty" pads were equal to the OE front pads. I think the front brake performance is "ok" it does not seem to be as powerful as the OE setup was. I now think the Napa "Ceramix" pads would maybe been a better choice.
Old Apr 10, 2004 | 01:45 PM
Tom's Avatar
Tom
I wouldn't worry too much about the rear break pads. OEM pads should do just fine, but if you would like aftermarket pads, I recommend Bendix. Ceramic break pads are not supposed to fade when they get hot, but they do not necessarily stop faster.
Whether or not you get top of the line pads isn't really a huge issue, anyway. Only 30% of all the breaking force goes to the rear tires anyway, the front breaks do most of the work. You may risk locking the rear tires when you hit the breaks if you get expensive pads, and the truck won't stop faster!
Old Apr 10, 2004 | 02:34 PM
HomerWinzlow's Avatar
HomerWinzlow
Is rust that much of a problem where you are from? Ive been a state inspector in 3 states and have never seen excessive rust on rotors as a disqualifier.. sheesh..
Old Apr 10, 2004 | 04:27 PM
TEEJAY's Avatar
TEEJAY
I had problems with a few other brands of brakes and finally sprung for Raybestos Quiet Stops. I have been very pleased after using them for about a year. Never any noise or dust and there only about half way down. They are worth the price!
Old Apr 10, 2004 | 04:42 PM
flaminf150's Avatar
flaminf150
I work at a dealership in canada and as a ford dealer we will put on aftermarket brakes when requested and have never had problems the only thing i would recommend is to match the same pads all the way around.
Old Apr 10, 2004 | 05:18 PM
01' Super Crew
To Homer ...Yes rust is a big concern here in N.Y. I had 25,000 mi on the truck when it failed, the inside surface was almost completely gone except a 1/4" wide band of smooth surface. (warranty would not cover this I was told by my dealer connection) To flamin F150....I spent 19 years working for Ford & Lincoln dealers in the parts dept. I agree about matching things, if I found better performance from whatever I put on the rear I would switch the front parts to the same. I never had a bad set of OE pads. It was the only type of brake pads/shoes I used whenever my 89' Bronco needed brakes in it's 147,000 mile life span. I have now moved onto class 8 parts departments at a Freightliner dealer for the last 4 years and in doing so, lost touch with what the light truck techs are using for parts. Thanks for the input everyone.
SkySkiJason
Sep 28, 2015 06:31 PM
PaxtonShelby
Jul 10, 2014 10:22 AM
KMUL
Jan 10, 2010 01:16 PM
week0019
2004 - 2008 F150
Oct 31, 2008 09:35 PM
nb1997
Jan 30, 2005 09:08 PM
