quick question on carrier
Old Apr 10, 2004 | 08:15 AM
IRULE's Avatar
IRULE
1998 f-150 5spd and im going from 3.55's to 4.10's. i know the fronts an 8.8 reverse rotation but my question is wether or not ill need a carrier for the front. i know you did in the danas. and if i do,why? why wouldnt i be able to use the current carrier?
Old Apr 10, 2004 | 11:25 AM
wildjon300ci's Avatar
wildjon300ci
Ford never put an 8.8 in the front...
Old Apr 10, 2004 | 11:34 AM
SoCalDesertRider's Avatar
SoCalDesertRider
I don't know where (or if) the carrier break occurs in the 8.8, but on some axles it's 4.10 and down, 4.56 and up. When I had my reverse rotation Dana 60 front done, I went from 3.55 to 4.56 and did not need a new carrier. Didn't need one on the rear 10.25" axle either. I don't know about the new F150's but the older ones had 8.8 in the rear and Dana 44 TTB in the front.
Old Apr 10, 2004 | 02:18 PM
IRULE's Avatar
IRULE
yeah they did.
Old Apr 10, 2004 | 07:09 PM
Boss_358's Avatar
Boss_358
1997 to 2003 F-150's use an 8.8 Visteon reverse rotation center section in the front. I wouldn't really call it an axle. I don't know what the 2004's use yet. Have not had a chance to check them out. I would assume that the 2004 F-150's still use the 8.8. I just know that they set them up a little bit differently with the rack and pinion steering.
Old Apr 10, 2004 | 08:25 PM
MustangGT221's Avatar
MustangGT221
The confusion is due to the fact that from 87 to 96 and maybe a couple years after that, ford used a solid 8.8 out back on the F-150s.
Usually the place you buy the gearset from, will have a note saying whether or not you need a new carrier.
Old Apr 13, 2004 | 12:23 PM
Boss_358's Avatar
Boss_358
I believe Ford still uses the 8.8 in the rear of F-150's. I think only with the 4.6 though.
Old Apr 13, 2004 | 04:55 PM
Commo's Avatar
Commo
Randy's pinion will give you a breakdown of everything you need.
I have a Dana 44 front and an 8.8 in the rear. Going from 3.55's to anything above 4:00 will cause you to need a carrier. If you put in a locker you won't need the carrier. Thats my story and I'm stickin to it.
Roland
