97 Ford Expy
Old Apr 9, 2004 | 06:10 PM
FozzieBear's Avatar
FozzieBear
97 Ford Expy
Hi everybody,
I'm new at this, here goes.
I purchased a used 1997 Expy a year ago and just in the past few weeks
I have had problems with the shifter, when i push in the brake it will not change into gear or i have to push the brake pedal in all the way to the firewall to get it to shift out of park can anyone help?
Old Apr 9, 2004 | 07:49 PM
PaulC's Avatar
PaulC
BOO!
The Brake On/Off switch is going bad, or is loose on it's (under the steering column) mount. This switch performs several functions, including releasing the electric lock that keeps the shifter locked in Park until the brake pedal is depressed.
Bet your brake lights won't work during these episodes.
If the problem deteriorates to the point that you can't shift out of Park at all:
1. Turn the engine off.
2. Turn the key forward just enough to release the shift lever, but not so far as to activate the instrument cluster warning lights.
3. Shift into Neutral.
4. Start the engine, shift into gear and drive away.
Old Apr 9, 2004 | 09:30 PM
FozzieBear's Avatar
FozzieBear
cAN I GET THE SWITCH REPAIRED? OR REPLACED?
Old Apr 9, 2004 | 10:14 PM
FTE Herman's Avatar
FTE Herman
Probably not. And with a problem as severe as yours I'd try to sell off the vehicle before it can no longer be moved. Its a little old but I'd be willing to give you a couple of hundred sollars for it.
No silly, of course you can get it fixed (I'd replace the switch actually). If you follow the lever leading up from the break pedal you will find the switch. Its not too hard to replace but if you feel uncomfortable doing it, simply take it to a local independent shop for repair. You can always take it to the dealer but that might cost a bit more.
Old Apr 9, 2004 | 11:05 PM
HomerWinzlow's Avatar
HomerWinzlow
Be sure to check for broken wires at the connector first, that is a problem that has plagued Ford for years.
Old Apr 14, 2004 | 09:29 PM
FozzieBear's Avatar
FozzieBear
Thumbs up tHANKS
You guys where right on the money for the switch problem
I have recommended you to 4 of my friends who own fords.
thanks again
dlcorbett
2015 + Expedition & Navigator
Oct 3, 2015 08:45 PM
JCs2004EXPI
Jan 10, 2011 06:35 PM
shakespearesdad
General Automotive Discussion
30
Jul 30, 2005 06:04 PM
oahuobx
Oct 22, 2003 11:43 PM
