Horn Relay
Apr 8, 2004 | 09:16 PM
Horn Relay
I'm having trouble locating it. anyone know where Ford put it on my truck? It is a 1979 F150
Apr 8, 2004 | 10:12 PM
on the right fender between the starter relay and the cowl.
Apr 8, 2004 | 10:40 PM
Thank you, that will help
Apr 8, 2004 | 10:44 PM
Check out my gallery. Look at more 77. There are a couple of pic of it.
Apr 8, 2004 | 11:04 PM
Unless you have cruise control, you don't have a horn relay.
If you do have cruise control, the horn relay is behind the instrument cluster attached to the Dash Brace..
Apr 8, 2004 | 11:29 PM
Then what's that on my fenderwell? If I unhook it, the horn doesn't work. Or is this something that changed on the 78/79's.
Apr 8, 2004 | 11:48 PM
Apr 9, 2004 | 12:20 AM
Figures, Just when I though I had some really good info with pic's, I'm fooled again.
Apr 9, 2004 | 12:30 AM
Check your Haynes manual.
Page 229.
You will see side by side.
Horn switch >< No cruise
Horn switch > Horn relay <> with Cruise
When I bought my Truck, I commented that the horn sounded quite weak to say the least.
Found out No Relay, everything comes from the battery thru the switch to the horn.
A few weeks later when comparing another truck, that truck had a great horn
I was told that truck has cruise....yours doesn't.
My truck now has a set of dual tone horns from an old Buick.
Man those are loud
Apr 9, 2004 | 12:37 AM
Learn something new every day. And it's less than 2hrs into today. I may have brain overload by tonight!!
Ford79
Sep 22, 2011 09:41 PM
mgazak
21
Nov 18, 2002 11:51 AM
Vampiro
Oct 13, 2002 08:08 PM
Distinctive Dave
Sep 10, 2002 09:53 PM
mavman
1997 - 2003 F150
Mar 5, 2002 11:59 AM
1973 ,
1977 ,
79 ,
88 ,
bronco ,
diagram ,
edge ,
f100 ,
ford ,
horn ,
mustang ,
ranger ,
relay ,
switch ,
work
