General Automotive Discussion
Desperately seeking Windstar help!!!
Old Apr 10, 2004 | 03:53 PM
parks911's Avatar
parks911
Originally Posted by parks911
Is it a jumping jerk? Hard to accelerate becasue it is jumping hard but once you get up to speed at it mellows out but you still notice it there?
When you floor it it doesn't jerk bad but you still notice a bad throttle response?
Now if the symptoms are like I quoted above then I would check the mass air flow sensor again. If not then check the intake air tube. If it is cracked, cut or broke badly it will allow to much air to come into the intake causing the problem quoted above.
I just had those problems with a mazda and it surprised me when I finally figured it out.
Old Apr 10, 2004 | 11:19 PM
X-1's Avatar
X-1
I would think either IAC valve, or FPR, fuel pressure regulator, probably the FPR. These can go bad, and will act like a bad o2 sensor, and over time will cause the o2 to go bad, this is a fairly inexpensive part that can be purchased from the local auto parts place.
Old Apr 11, 2004 | 02:03 AM
Ford_Six's Avatar
Ford_Six
What does the speedometer do when the vehicle is jumping? Does it waver more than you feel it should? Do any lights come on then?
Old Apr 11, 2004 | 08:40 AM
drighten's Avatar
drighten
One thing I have not noticed mentioned here. You should find a shop you are comfortable with, that seems to know what they are doing, and then stick with that shop until they find the problem and fix it. I know, another problem is as you mentioned - a shop that you feel was ripping you off. I think this is why someone previously mentioned finding a better dealer service center. If you do go from shop to shop - every shop has to start from scratch, without a record of what has been done. Also, any shop that guarrantees their repairs by redoing them free of charge is a good bet. It happens sometimes that the brand new part that is replacing the bad one is bad too, so a shop that will check this is reasonably trustworthy. I spent a lot of years finding a shop that is professional, good at what they do, and honest. I stick with that shop even though my vehicle is under warrantee. Only the warrantee work goes to the dealer BUT I have full documentation on any work done, and it is done by a Class A mechanic so as to maintain the warrantee.
Old Apr 11, 2004 | 07:20 PM
cmcaninch's Avatar
cmcaninch
I am also haveing the same or sounds the same except mine is giveing me 3 codes
P0300 (random multiple misfires) P0161 (O2 downstream sensor) P1407 (egr no flow detected) I have replaced the O2 so far no improvement I also have had the motor replaced 60k ago hopeing not to do that again
Old Jun 2, 2004 | 04:18 AM
cmcaninch's Avatar
cmcaninch
I finally found my problem
it turned out to be a broken vacume tube that connects to the metal tube off the egr valve couldnt see it because it was in a steel braded cover fixed the tube runs great for now!
Old Jun 2, 2004 | 07:36 AM
drighten's Avatar
drighten
I guess those codes do work, don't they. A P1407 just about pinponts a no vacuum condition at the EGR, doesn't it. For a bit of a sceptic like me, it is good to see something point to the problem. I guess if I worked with autos and the codes all day, like a mechanic would, I would start to have more faith in the diagnostics computers. It just seems that every time 'I' have a problem - I don't get a code.
gzilla46
36
Oct 5, 2012 05:45 AM
Kim's Hipster
Mar 23, 2011 03:46 PM
460
17
Apr 19, 2009 08:58 PM
dancheck
Sep 13, 2004 06:10 AM
parks911
15
Jun 25, 2004 05:48 PM
