Sponsored by: Innova
Stero Problem
Old Apr 8, 2004 | 08:00 PM
Drfeelgood's Avatar
Drfeelgood
Stero Problem
I was installing my stero and i had everything working fine all wires were hooked up right and when i went to put it in the whole stero flickered. Then I figured maybe it would jus happen once but then it jus shut off completly and won't turn back on at all. Iv tried many other things and i checked the fuse to. Any sugjestions?
Old Apr 9, 2004 | 07:25 PM
bill6302's Avatar
bill6302
check all the connections. make sure you used good crimps, hit the reset button on the radio and that should fix it.
Old Apr 10, 2004 | 10:37 AM
Drfeelgood's Avatar
Drfeelgood
yeah i did that like four times
Old Apr 13, 2004 | 02:16 PM
ac_fordforever's Avatar
ac_fordforever
check all your fuses not jus the radio and head unit fuse. then check to see if any of the wires shorted. like if the connections crossed or the installation melted. did smoke come out of the deck?
Old Apr 19, 2004 | 08:05 PM
Drfeelgood's Avatar
Drfeelgood
yeah that did happen and i found out i kept blowing the radio fuse in the pannel because i didn't ground the case of the radio and smoke did come out of the dash board near the radio. Thank you for everyone helpin me
Old Apr 20, 2004 | 09:14 PM
supra88's Avatar
supra88
the radio will burn if it take the groun from the antenna
