Help!!!!!
Old Apr 9, 2004 | 11:33 AM
johnsdiesel's Avatar
johnsdiesel
I've never replaced a turbo and can't give you any idea what it would cost, but my guess is that it is not cheap. You might want to check with some of the big online diesel shops that sell rebuilt turbos and see if they will either rebuild your turbo or sell you a rebuilt at a discount for the exchange. I know Diesel Injection Service ( www.dieselpage.com ) sells rebuilt turbos. Maybe you could buy the parts and rebuild the turbo yourself.
Old Apr 9, 2004 | 12:19 PM
basstardo's Avatar
basstardo
Dude, you're turbo is covered under the 5yr/100k mile ENGINE warranty. Look on page 7 of the diesel supplement to your owners manual. It tells you everything that is covered. Turbocharger is one of them. It will cost 100 bucks for the deductible. They'll fix the turbo and any incidental damage. If they say they won't, pull out the book and show em in black and white. I've been through this three times with the dealer, so don't let them push you around.
Old Apr 9, 2004 | 12:24 PM
basstardo's Avatar
basstardo
Here ya go man, this is direct from the Ford web site:
6.0L/7.3L PowerStroke Diesel Engine Coverage
The New Vehicle Limited Warranty covers certain direct injection diesel
engine components against defects in factory-supplied materials or workmanship
for five years after the warranty start date or 100,000 miles,
whichever occurs first.
After the end of the Bumper to Bumper Coverage period (three years or
36,000 miles, whichever occurs first), you must pay a $100 deductible for
each repair visit.
Ford Motor Company or Ford Motor Vehicle Assurance Company covers
these components: cylinder block, heads and all internal parts, intake
and exhaust manifolds, timing gear, harmonic balancer, valve covers, oil
pan and pump, water pump, fuel system (excluding fuel lines and fuel
tank), high pressure lines, gaskets and seals, glow plugs, turbocharger,
powertrain control module, electronic driver unit, injectors, injection
pressure sensor, high pressure oil regulator, exhaust back pressure regulator
and sensor, camshaft position sensor, accelerator switch.
NOTE: Some components may also be covered by the Emissions Warranties,
with no deductible. For more information, see pages 11-24.
Old Apr 9, 2004 | 12:59 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
So Basstardo, what you're telling me is that the warranty will cover the damage caused by the K&N filter? Also, it won't be voided as a result of the K&N filter seeing as it was incidental damage? By "incidental", I mean that I didn't know that the filter would damage the turbo.
Old Apr 9, 2004 | 01:38 PM
basstardo's Avatar
basstardo
Honestly, that all boils down to the dealership. Some of the dealers in my area go as far as to sell aftermarket stuff, others really shy away from it. The biggest catch to the whole engine warranty is the dealer has to prove the aftermarket product caused the failure. In this case, it's pretty apparent, but ya never know until you actually tear into the turbo itself. For all we know, there could have been a defective part in the turbo when it was assembled, but gettin the dealer to realize that is a different story. I do think though that if you take it to the dealer, they'll fix it. If they don't try another dealer. It's worth a shot and may end up savin you some cheddar in the long run.
Old Apr 9, 2004 | 09:00 PM
Toreador_Diesel
Originally Posted by basstardo
.......wouldn't seal right, and there was a considerable amount of dust(enough to feel gritty) inside the intake duct. .......If not, bite the bullet, get the turbo repaired (or get a Garrett GTP38R Ball bearing turbo) .......Terry
I took apart my intake to look at the turbo again and it is, as you said, gritty. If you look in my gallery, you'll there's a "periscope" that comes through the intake duct. This is where I found most, if not all of the dirt. What is it for? and Not that I can afford a new turbo, but what advantages does a Garrett GTP38R Ball bearing turbo have over the stock one?
Old Apr 9, 2004 | 10:40 PM
johnsdiesel
That periscope is from the breather element. It's not unusual to have a little bit of oil buildup there. The grit had to come from the intake though. Some of the grit tends to stick to the oil that does make it through.
Bar B Q
Feb 27, 2015 06:36 PM
Bar B Q
Feb 22, 2015 06:34 PM
hink10
Jun 4, 2013 07:31 PM
oldbird1965
23
Oct 29, 2012 11:32 PM
saycheessee
Sep 3, 2009 08:06 PM
