tranny temps
Old Apr 8, 2004 | 03:51 PM
CBWARDJR's Avatar
CBWARDJR
Question tranny temps
Any idea what tranny temps should be under no load, 4x4, long bed, super-duty, automatic, 7.3 dsl, 1999, 3.73 gearing.
mods: mag-hytech 7 qt tranny pan; all gauges; ais intake w/"zoodad tric"; 4" dpipe back bd pipes; latest smct programmer
Old Apr 8, 2004 | 05:36 PM
CAT_man_963's Avatar
CAT_man_963
My truck running around empty but running long enough to get fully warmed up runs right around 130* or a little above. I have a sonnax valve and tri-springs so I don't know if that makes a difference either way.
Old Apr 8, 2004 | 05:49 PM
CBWARDJR's Avatar
CBWARDJR
thanks,
my gauge has yet to move off of 140 degrees with my current setup. Was worried the gauge was faulty!
Old Apr 8, 2004 | 06:17 PM
red4x4's Avatar
red4x4
Mine was at 130, but today after changing the trannny fluid, it stays around 150. Strange that it went up with new fluid.
Old Apr 9, 2004 | 07:33 PM
TJC1989's Avatar
TJC1989
That is interesting. Is it overfull, and churning up foam?
Old Apr 9, 2004 | 08:44 PM
Pilot's Avatar
Pilot
What transmision temp. is too hot when towing a 13200 # 5th wheel?
des
Old Apr 9, 2004 | 09:23 PM
Quadzilla's Avatar
Quadzilla
Once you get the tranny fluid over 200 degrees, you start shortening it's life. In response to a previous question, I just got back from a 200 mile drive in 75-80 degree heat, and my tranny temp gauge sat on 150 the whole time, running empty at 70mph. When it's colder out, it typically runs at 125-135.
Old Apr 9, 2004 | 09:45 PM
Fire Rooster's Avatar
Fire Rooster
Pilot,
Just curious what your tranny temp is while towing?
Fire Rooster
Old Apr 10, 2004 | 06:45 AM
Pilot's Avatar
Pilot
Tranmission Temps.
Pulling temps are between 110 and 120 on the highway. In traffic with a lot of stop and go they got to 180 with outside temps in the high 70's.
pilot
Old Apr 10, 2004 | 12:53 PM
Fire Rooster
Cool Thanks
