whistling noise
Old Apr 8, 2004 | 03:40 PM
WaR38's Avatar
WaR38
Question whistling noise
I have a 87 f-250 with the straight six. There is a whistling noise at idle but when I accelerate the noise stops. I belive that it is a vaccum problem. I just don't really know where to check. Any hints?
Old Apr 8, 2004 | 05:55 PM
4x4lowandslow's Avatar
4x4lowandslow
Only time I've experienced this was when I ran a vehicle without the intake hoses on and the "whistling" was the intake air sucking into the throttle body. Noise goes away after you crack open the butterfly more. Check your intake system.
Old Apr 8, 2004 | 06:14 PM
fordberg's Avatar
fordberg
Same here. Throttle body. Check the bolts on the carb to manifold. They always came loose on my 300. Has anyone rebuilt the carb lately or put on a non-stock air cleaner?
Old Apr 8, 2004 | 06:19 PM
WaR38's Avatar
WaR38
well its fuel injected. but ill look into the air. also my friends dad runs a truck repair shop. he says it may be a alternator problem. any thoughts on that. he didn't think it was a vaccum problem
Old Apr 8, 2004 | 06:39 PM
4x4lowandslow
Get under the hood and isolate the problem. I'm assuming you do have an air filter installed. Pull off the intake hoses going to the throttle body(if it sounds like it's the locale) and it'll scream at you if it's the problem. Run the throttle with your hands and get dirty. Be one with the truck.
Old Apr 8, 2004 | 08:22 PM
WaR38's Avatar
WaR38
haha alright. thanks alot folks.
Old Apr 8, 2004 | 08:59 PM
speedyredford's Avatar
speedyredford
I had a whistling on an older car, not a Ford though, it emmitted from the alternator, apparently the bearings were going, and about 60mi later, it seized and the belt burned and snapped. No damage, and we drove it home, so not to worry too much if that is it, but something to think about.
Good Luck.
