changing rearend
Old Apr 8, 2004 | 12:41 PM
papabear59's Avatar
papabear59
Cool changing rearend
will a 94 ford powerstroke rearend fit under a 88 ford f-350 ?
Old Apr 10, 2004 | 10:24 AM
SoCalDesertRider's Avatar
SoCalDesertRider
They should both be Ford Sterling 10.25" rear ends as long as the F350 we're talking about is a single rear wheel truck, not a dually. If both are single rear wheel axles, as long as the ratio is the same, I don't see a problem swapping them. If one is a dually and the other is a single rear wheel, then there will be issues with wheels, brakes and leaf springs. Some duallies use the Dana axle too.
