Need help with wire identification
Old Apr 7, 2004 | 07:24 PM
Drfeelgood's Avatar
Drfeelgood
Exclamation Need help with wire identification
Im trying to replace my stero in my 1989 F-350. Im having trouble trying to figure out which wire is which. If anyone could help me Identifing what wire is what it will be greatly appreciate it. And also I have an amplifier and a subwoofer and when i turn the stero up loud the woofer hooked threw the amp shuts off during low notes.
Old Apr 7, 2004 | 07:39 PM
LoosMaster's Avatar
LoosMaster
Not to up on this, post your question in the Audio and Video forum, they might be able to help.
Old Apr 7, 2004 | 07:55 PM
acerockola77's Avatar
acerockola77
This site has all the wiring diagrams: http://www.installdr.com
What gauge of wire are you running to your amp? Can you post a little more info?
Old Apr 7, 2004 | 08:25 PM
Drfeelgood's Avatar
Drfeelgood
Wire gauge
What gauge of wire do u sugjest? I had it hooked up last week and i know i did it wrong because when i turn the headlights on the stero will come on without the key in the ignition. But there are three other wires that were hooked into the stock stero that im not using, so i figure that one of those is for the memory and the other something else.
Old Apr 7, 2004 | 09:40 PM
acerockola77
The gauge depends on the size of your amp, how big is it?
By it comming on when you turn your lights on, it sounds like you hooked it to the dimmer switch or something, that's weird. I always preach using harnesses, that way you really can't go wrong, but I'm guessing you cut those off. Did you take a look at the wiring diagram at installdr?
Old Apr 7, 2004 | 10:19 PM
alabamabuddog's Avatar
alabamabuddog
Go to Auto Zone and buy a plug.
Old Apr 8, 2004 | 02:07 PM
Drfeelgood's Avatar
Drfeelgood
Ya i think i did hook it to the dimmer. But i cannot find a wiring diagram on my truck and there isn't anything about it in the manual.
