Sponsored by: Real Truck
F350 brake problem
Old Apr 7, 2004 | 08:23 AM
CHUNK 65's Avatar
CHUNK 65
F350 brake problem
Hope someone has an answer to my problem. I work for the local Transit Authority and we maintain all of the ambulances for the county. The whole fleet is F350s and they were ordered from Ford with the ambulance package. The problem is that the brakes are the same as standard F350 that you can buy from your local dealership. We cannot keep brakes on these vehicles. Our average mileage between brake jobs is from 3,000 to 6,000 miles. The main problem is the calipers. The dust boots are tearing and melting. I know this is do to heat. I was wondering if anyone knew of a possible solution. I have tried different brake pads and different rotors, but that is not curing the problem. I have tried to find larger disks and I am unable to find them . Part of the problem is that the front rotors and hub are a one piece part and I have been unable to find anything larger. Any help would be appreciated. Hopefully I have explained the problem fully to you. If not, let me know. Thanks, Keith
Old Apr 8, 2004 | 07:20 AM
Burr's Avatar
Burr
Dont have a salution, but the same problem on a couple tow trucks (99,04) I maintain. So your not alone.
So far all I've been doing os the same, cals and pads. I am getting more than 3,000~6,000 miles out of them though.. eek
Old Apr 8, 2004 | 07:29 AM
Backhoe Pilot's Avatar
Backhoe Pilot
Have you tried to find drilled and slotted rotors for the vehicles. Maybe this will help with the heat problem. How much do the ambulances weigh? Could they be overloaded? I have a 2001 F-350 and have problems with my brakes. Mostly, warped rotors. The pads wear fine.
Old Apr 8, 2004 | 08:40 AM
CHUNK 65's Avatar
CHUNK 65
They weigh around 15,000 lbs. I can find drilled/slotted rotors, but they are the rotor only(front) and I need the hub and rotor assembly together. Also these ambulances have dual rear wheels. Motorcraft makes a rotor that they list as a "severe duty" rotor, part #BRR-93(front)and BRR-96(rear). They also list a "severe duty" pad, part #BRSD-757(rear) and BRSD-756(front). These part #'s were given to me by a guy at "Ford Fleet". They have helped some , but we are still having unusual brake wear. Maybe these part #'s will help you out on your personal vehicles.
These were ordered from Ford as an ambulance package. I would have to think that they know the kind of weight that will need to be supported.By the way, these are "Superduty" vehicles.
Old Apr 8, 2004 | 11:07 PM
bcs's Avatar
bcs
Yep 15,000 is too much for the 350. I thought the max on a 350 is 11,500.
Also you said "The main problem is the calipers. The dust boots are tearing and melting. I know this is do to heat." So the brakes are doing what they are supposed to do, turn momentum into heat. Sounds like you already know what needs to be done, more cooling.
You did not say you had a warping problem or fade issues. I think cross drilling and slotting will only help fade issues by allowing the pad outgassing gas a path to escape.
So not much help.
If you had warping and fade issues I would say you should try some of the ARTs Cryo and slotted rotors.
http://member.newsguy.com/~nutech/frames.html
Applied Rotor Technology
I think you should try them anyway then you could let us all know if they work like the say they do or not
jtravel
Jul 5, 2020 05:38 AM
Toulousse
General Automotive Discussion
Sep 11, 2016 06:43 AM
lawdawg79
Jun 13, 2015 02:02 PM
joey2fords
Aug 25, 2014 08:59 PM
mediccuz
Feb 2, 2006 05:14 PM
