Sponsored by: Auxito
weird starting problem
Old Apr 7, 2004 | 02:12 AM
oneduke's Avatar
oneduke
I have a 01 supercrew 4.3 , one day it runs fine the next it wont start. garage guy hauls it away says he pushes the schrader valve on fuel rail it gives a little burp. He gets it running checks fuel pressure, ignition, plugs everything is ok. No codes at all. It seems to run fine now but I am sure that it will quit 2 hours from home. He says there was air in the fuel line and it wasnt getting gas. I didnt let it run out of gas to get air in the lines. Any thoughts on how or if this could happen spontainiously? The truck only has 43k on it and is bone stock.
Old Apr 7, 2004 | 04:18 PM
triton_2002's Avatar
triton_2002
What exactly does it do when it won't start? Does it crank over or nothing at all? Maybe its a plugged up fuel filter? Has it been changed? Just a thought.
Old Apr 7, 2004 | 05:25 PM
FourthFordTruck's Avatar
FourthFordTruck
Sounds like our Expedition when the IAC was clogged and faulty.
Would start, then not, then start. No code was ever thrown.
Replaced the IAC and no probs.
Old Apr 7, 2004 | 07:08 PM
Rambo's Avatar
Rambo
I'm somewhat new to truck mods and such, whats IAC stand for?
Old Apr 7, 2004 | 07:48 PM
oneduke's Avatar
oneduke
yes it just turns over but wont hit, it turns over fine
Old Apr 7, 2004 | 08:30 PM
1979ford's Avatar
1979ford
IAC stands for idle air control, sounds like fuel filter, or maybe the pump has a bad connection.
Old Apr 7, 2004 | 08:41 PM
bosshoss's Avatar
bosshoss
Might have a fuel pump going bad. How many miles on the truck? Next time it quits, if you dont have a fuel pressure guage. Listen for the fuel pump to cycle. turn off every thing and listen closely for a little whine then it will stop. Might have a friend listen at the fuel tank for the pump to start then stop. If it wont start, try tapping the bottom of the fuel tank with a hammer with the key on, the tank is strong, so give it a firm tap, just dont slam the tank with a 10lb sledge.
Old Apr 7, 2004 | 10:11 PM
LxMan1's Avatar
LxMan1
Could be because it has a GM 4.3 in it HEE HEE
Old Apr 7, 2004 | 10:43 PM
F2504x4's Avatar
F2504x4
good call.. lxman1
Old Apr 8, 2004 | 09:16 AM
FourthFordTruck
Hah! I figured it was a typo on 4.2. When the Expedition
wouldn't start and run right, I changed the fuel filter twice.
No change. It would run when I gave it a lot of gas upon
ignition, but of course you aren't supposed to do that with a fuel injection engine.
Changing the Idle Air Control solved it all.
Old Apr 8, 2004 | 01:48 PM
LxMan1's Avatar
LxMan1
Well, it could be a 4.2 or a 4.6. The 2 and the 6 are both next to the 3 on the keyboard. But then again, it could have a 4.3 transplanted in there.
Old Apr 9, 2004 | 12:54 PM
bosshoss's Avatar
bosshoss
NOOOO. Not a transplant of the Gm kind. Say its not so. I feel faint. dizy, boom.
Old Apr 9, 2004 | 01:06 PM
FourthFordTruck
Hello, OneDuke. Any progress, input? What is the true size of your engine?
Old Apr 9, 2004 | 11:21 PM
LxMan1's Avatar
LxMan1
All kidding aside, Will the truck start if you give it a bit of gas when cranking?
