Sponsored by: Auxito
2002 F-150 IAC Problem
Old Apr 6, 2004 | 11:41 PM
robjef's Avatar
robjef
I have a 2002 F-150 XLT with only about 3000 miles on it, basically because I drive an older truck to work. Anyway, after having not driven it for about 2 months, I decided to drive it today. To my amazement, the darn thing would not start. It would turn over but would die immediatly. Since, it is still under warranty, I figured I would have to have it towed to the dealer, but decided to try this great forum first. I found a thread that seemed to speak of similar symptoms on a 1998 F-150. The solution given in the thread was to tap on the IAC valve, because it may just be stuck. This was a great suggestion, because that's what I did and it started right up. My question is......with my truck being just under 2 years old with hardly any miles on it, does this seem normal? Should I try to get the Ford dealer to change the IAC valve under warranty, although they will probably say they can't find any problems with it? This just seems too early to be worrying with this type of problem on a truck of this age. Any suggestions or comments would be welcome. Thank you.
Old Apr 7, 2004 | 06:31 PM
Racerguy's Avatar
Racerguy
Since it sat for 2 months and has been working ok I dont think I'd worry about it.
Old Apr 7, 2004 | 07:34 PM
HomerWinzlow's Avatar
HomerWinzlow
Low mileage is one thing, low mileage and long storage is another. All kinds of problems can develop from inactivity... battery problems, gumming up of the fuel system, vapor/water contamination, seal leaks, etc. And consider that your truck may have sat on a lot for months before you even purchased it. Drive that baby more often and keep its juices flowing.. It will serve you better.. IMHO
Old Apr 8, 2004 | 09:39 AM
FourthFordTruck's Avatar
FourthFordTruck
This is goofy question, but here goes. Where is the IAC on a '99 5.4?
It's not in the same place as a '97 4.6, and a mechanic
replaced ours before I found this forum and learned to
change the 4.6 IAC myself. I see the EGR, but not the IAC.
Thanks in advance. Also, the EGR port clogging problem, is
that a 5.4 thing as well, or strictly all 4.6? This site rocks.
Old Apr 8, 2004 | 08:09 PM
Racerguy's Avatar
Racerguy
The IAC should be behind and to the left of the throttle body.
If you remove the black plastic cover over the throttle body you should be able to find it.
Old Apr 9, 2004 | 05:06 PM
FourthFordTruck
Looking at the throttle body, behind and to the left?
I didn't see it. I'll take the cover off and look again
tonight. On the 4.6, it's behind and to the right when
looking at it. Is it the same cylindrical shape?
On the EGR port clogging, I've never gotten a response to whether
this carbon buildup also happens in 5.4's. I know the set up is a little different. Thanks.
Old Apr 10, 2004 | 01:42 AM
Racerguy's Avatar
Racerguy
The IAC looks the same on both the 4.6 and 5.4.
I believe that some people on here have had plugged ports on the 5.4 as well.
Dragon67
Dec 29, 2015 01:45 PM
bunruh
Nov 1, 2013 06:24 PM
manchu76
Modular V8 (4.6L, 5.4L)
Jul 12, 2013 02:05 AM
f150nca
2004 - 2008 F150
Apr 21, 2011 09:57 PM
offlinepk
1983 - 2012 Ranger & B-Series
Oct 25, 2010 01:54 PM
