Dang that's tight
Old Apr 6, 2004 | 10:02 PM
b2_tim's Avatar
b2_tim
Dang that's tight
I tried to get my plug out of my 2003 8.8 F150 diff and it wouldn't budge. I used the 3/8 socket extension. Is there a better tool? Should I heat it, or just have another beer? Ford said it is lubed for life, yea right. It does look like they used some locking compound on the threads. Thanks for any tips.
Tim
Old Apr 6, 2004 | 10:18 PM
King Triton's Avatar
King Triton
when they get tight like that,I take a 3/8 ext,put it in the hole,smack the end of the ext a couple times with a hammer to help jar it alittle,then I use a 3/8breaker bar and a pipe on the breaker bar,that almost always breaks them loose.
Old Apr 7, 2004 | 07:49 PM
shotgun's Avatar
shotgun
Pb Blaster
and give it a good shot of PB BLASTER....
Old Apr 7, 2004 | 11:02 PM
b2_tim's Avatar
b2_tim
Got it!
That PB blaster is good stuff.
Thanks
Old Apr 7, 2004 | 11:12 PM
FERacing66's Avatar
FERacing66
yeah get a breaker bar and shoot some penetrating oil on it.
Old Apr 7, 2004 | 11:32 PM
rebocardo's Avatar
rebocardo
> Is there a better tool? ... Thanks for any tips.
I have not worked on a new Ford since 2000, though I do believe yours is a metric fitting and not 3/8 and will round out if an extension is used. Most likely it is on with red lock-tite. There is a lock-tite (green?) that can be applied and it will seep in and destroy the red without having to use heat.
Old Apr 8, 2004 | 05:53 PM
b2_tim's Avatar
b2_tim
Wheew thanks
You were right it is red lock tite. I'll have to look into the different colors. I have always used blue. And who would have thunk they would use metric on the square hole. Looks like I need to buy another tool, (not a bad thing).
I tried it with the 3/8 extension, and it just didn't feel right, very sloppy. I put a few dents in the inside lands, but nothing drastic. Sure wasn't looking forward to applying head to a LSD rear end.
Thanks
