Shocks/Stabilizer
Old Apr 6, 2004 | 06:13 PM
vegetablering's Avatar
vegetablering
Question Shocks/Stabilizer
I just put new shocks on all four corners, while under the rear end I noticed a small shock, which I am assuming prevents rear end sway. This "shock" comes off of the pumpkin and goes fwd and to the passenger side. It looks real rough. Does anyone know a ford part number, or an after market product that would fit?
Thanks in advance
Old Apr 7, 2004 | 10:12 PM
c96drumm's Avatar
c96drumm
That's a damper and I believe it's purpose is to prevent rear axle windup when you hit the gas, or something like that. Maybe just disconnect one end of it and make sure it still has resistance to push and pull and fugetaboutit.
Old Apr 8, 2004 | 03:15 PM
vegetablering
thanks, but if it is like the rest of myshocks and some of my bushing it is not in the best health, that is why I want a part number so I can cross reference it
Old Apr 8, 2004 | 03:28 PM
Opera House Works's Avatar
Opera House Works
For sure the bolt on the pumpkin will be worn because the cast bracket won't compress on the rubber bushing. At the least, switch the bolts. The top bracket will compress and will work OK with worn bolt.
Old Apr 8, 2004 | 04:16 PM
c96drumm's Avatar
c96drumm
Look at this: http://www.monroe.com/catalog_lookup...=1996&LST=2769
I can't tell for sure, but I think that is what you're after, the axle damper.
Old Apr 12, 2004 | 03:09 PM
vegetablering
thank you for your help, that looks like it
jeff8362000
Nov 19, 2009 12:44 AM
z1121jack
Sep 25, 2008 06:27 AM
sigtauenus
Nov 8, 2007 01:49 PM
AL Truck
New Member Introductions
Aug 2, 2005 03:15 PM
yozsi
Oct 1, 2004 12:16 PM
