fuel pump??
Old Apr 5, 2004 | 08:29 PM
Hardball's Avatar
Hardball
fuel pump??
How do you tell when your fuel pump needs replacing if you dont have access to a pressure guage.. does the engine run silly? I think I may have this problem... sorry for all these questions but I just came back from deployment for 8 months, and I am working bugs outta my old girl. Thanks.
Old Apr 5, 2004 | 08:36 PM
fordman428's Avatar
fordman428
one thing it may start then die or only run if u keep pumping the gas pedal, thats what happened when the fuel pump went out of my 390.
Old Apr 5, 2004 | 10:09 PM
LxMan1's Avatar
LxMan1
Usually if the diaphram is shot it will either put fuel into the crankcase (oil) or out of a hole in the housing. If the return spring is broken on the arm, it won't pump very well.
Old Apr 5, 2004 | 10:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can do a volume test by running a hose into a bottle and timing how long it takes to fill it. There are specs in service manuals. If you don't have one get one, and maybe someone will look it up for you tonight A simple pressure test is to put your finger over the end of the hose, just don't squirt the gas into your eyes or anyplace else dangerous.
Old Apr 5, 2004 | 10:56 PM
mark a.'s Avatar
mark a.
Mine just always seems to run out of power on hills. I seem to put one on every 3 years. I've never had one leak into the crank case, or leak outside the housing. I'm not saying it can't, but I've been through 470,000 miles on my truck.
Old Apr 6, 2004 | 08:36 AM
Hardball's Avatar
Hardball
thanks for the suggestions guys.
