engine mounts
Old Apr 5, 2004 | 05:15 PM
revrick's Avatar
revrick
Question engine mounts
I have a 68 Ranger with a 360 4 speed, I'm going to replace the 360 with a 240/300. Can I still use the trans, and do I need different frame to engine mounts?
Old Apr 5, 2004 | 05:17 PM
roadgemF100's Avatar
roadgemF100
They're the same, but mount in a different set of holes on the frame.
Old Apr 5, 2004 | 05:21 PM
revrick's Avatar
revrick
thanks, is the trans workable on the inliner?
Old Apr 6, 2004 | 11:21 AM
talisker's Avatar
talisker
I went the other way last summer. I replaced the 240 with a 360. Everything is compatable with just a chnage in the location of the various mounts (tranny and engine.)
Old Apr 6, 2004 | 11:46 AM
gtex's Avatar
gtex
The tranny must have a different bell-housing at least.....Maybe I'm losing my mind.
Old Apr 6, 2004 | 12:53 PM
talisker's Avatar
talisker
The tranny does have a different bell housing. I tend to think of the engine/clutch/bell housing as a unit. On my exchange I also had to fab up a mount for the motor side of the clutch bell crank. This may have been because the truck is a 69 and the new motor came from a 73. On my 69 240 there was a threaded hole that a pivot pin screwed into in the engine block. On the 73 360 there was no hole and I had to make a bracket to accept the threaded pivot pin.
Old Apr 6, 2004 | 03:18 PM
revrick's Avatar
revrick
Smile
thanks guys you've been a great help
