posi trac
Old Apr 1, 2004 | 08:13 PM
boogity24's Avatar
boogity24
posi trac
do all the 67-72 ford trucks come with posi trac, or just certain ones, because both my wheels spin, and so do my dads 69
Old Apr 1, 2004 | 08:58 PM
roadgemF100's Avatar
roadgemF100
It was an option...most did NOT have it. If they both have anti-spin differentials, you've lucked out!
Old Apr 2, 2004 | 01:41 PM
boogity24's Avatar
boogity24
i just know, when i spin out, i have two big ole marks instead of just one, and can you identify that from the vin??
Old Apr 2, 2004 | 04:57 PM
bigric's Avatar
bigric
No, but there's a tag on the axle we could use, and there's also an axle code on the VIN plate that we could use. Give us either one and we'll tell you what you've got.
Old Apr 3, 2004 | 10:58 AM
boogity24's Avatar
boogity24
axle code:17
Old Apr 4, 2004 | 11:14 AM
Carico's Avatar
Carico
posi trac
the easiest way to tell a posi from an open differential is to jack both rear wheels off the ground and turn one of the tires. if one turns one way and the other turns opposite its not a posi. if they turn the same direction it is a posi.
Old Apr 4, 2004 | 11:04 PM
Mil1ion's Avatar
Mil1ion
Posi is a GM term.
Ford's term is: Limited Slip / Traction-Lock
Old Apr 5, 2004 | 12:16 AM
rmt's Avatar
rmt
If they EVER turn the same direction it's limited slip, if they ALWAYS turn opposite then it's not. Limited slip may not always turn opposite in the jacked up situation, a "normal" rear end will ALWAYS turn opposite. Limited slip may not turn at all on the other side in that situation. Turn the passenger side when testing.
Old Apr 5, 2004 | 04:14 AM
bigric's Avatar
bigric
Originally Posted by boogity24
axle code:17
3.25 open gears
Old Apr 6, 2004 | 02:46 PM
boogity24's Avatar
boogity24
and that means???¿¿¿
Old Apr 6, 2004 | 02:57 PM
bigric's Avatar
bigric
3.25:1 axle ratio. It's an economy ratio; the engine will turn lower RPMs but has to put in more effort to get the truck moving. It's more suited to highway cruising than pulling mobile homes away while their owners sleep. And it's not limited-slip, so it's possible for one wheel to spin while the other does nothing.
Old Apr 6, 2004 | 04:08 PM
boogity24's Avatar
boogity24
is that good?¿
