Bad Idle And No Low End Power
I Have A 92 Ford Ranger 3.0 Xlt 5 Speed. The Problem Is Rough Idle And Low Power At Lower Rpms Also Has A Small Surges At Higher Rpms..
I Have Changed Plugs, Plug Wires, Cap, Rotor Bug, Air Filter, Fuel Filter. Checked Timing That Was Fast Brought It Back To 10 Degrees. (which Made It Worse) I Also Noticed It Took A While For It To Even Back Out At Higher Ipm. I Have Ran A Can Of Bg Fuel Injector Cleaner Through A Full Tank Of Gas.....
Any Ideas??????
Any Ideas??????
Welcome to FTE, SNIPPEDFORLIFE!
Sounds like a vacuum leak to me. Get a vacuum tester to help you find the problem. Or a can of WD-40 and spray it on the lines where you think it might leak. If the idle chanes in any way, it means the WD-40 entered the system and got burnt through the cyclinder. Replace the line(s) and you should be set.
The spout jumper tells the 'brains' that you want to set the 'base' timing, the mechanical position of all the parts. Once you set the base at 10, you put the spout back in, and the ECM takes over and adjusts the timing for all situations.. hot/cold/accel/decel, etc etc. There should be a plug near the dist that has only 2 wires into/out of the connector. It is the spout jumper. Take it out when setting the initial timing, as noted above. Replace when done. I believe that it is a small rectangular jumper on the 3.0, about 1/2" by 3/4", that has a handle shape for the part that you remove.
I'd also check that your EGR was working properly, as they can cause 'trailer hitching' when you are running down the highway. Disconnect and plug the hose with a golf tee for testing purposes. Do not leave it disconnected as you will hate the pinging and poor gas mileage...
Pull the codes, as already suggested. There may be something there that will let you know what's broken or mal-adjusted.
tom
tom
bigcountry25
2004 - 2008 F150
08-21-2014 09:46 AM
carpe_diem
06-18-2014 09:54 AM
Cricklewood
1983 - 2012 Ranger & B-Series
18
02-22-2008 08:04 AM
