Used Bearing Preload
Old Apr 5, 2004 | 04:39 AM
mcanik's Avatar
mcanik
Question Used Bearing Preload
In my 1990 F150, I had to change out the pinion seal. My pinion was quite loose creating the oil leak in the first place. Is there a procedure other than the one in the Haynes or Chilton manual someone else can share?
Thanks in advance
Dan.
Old Apr 5, 2004 | 04:40 AM
mcanik's Avatar
mcanik
Forgot to mention........... 8.8
Old Apr 5, 2004 | 02:42 PM
mcanik's Avatar
mcanik
Well.......I am out of time. I need to put this together today. I am going to play it by ear and post my procedure if I can figure one out
Old Apr 6, 2004 | 02:09 PM
mcanik's Avatar
mcanik
Well......I finished the work. After I replaced the old leaking seal, I tightened the yoke until the end play was gone. I then turned the nut about 1/8th of a turn further. So far so good. Test driven the truck and all is good. I have no noises and no more high speed vibrations associated with the loose pinion as before.
I am not saying this is the right procedure. It is working for me but it is my alternate other than doing it the scientific book way.
novafreak66
Jan 31, 2010 12:57 PM
Blue86f150
Dec 18, 2009 03:36 PM
fitzy67
17
Sep 13, 2008 10:27 PM
tastyklair
Aug 23, 2007 11:12 PM
F100
Dec 30, 1999 11:39 PM
