Rearend Gearing
Old Apr 4, 2004 | 10:09 PM
Sanders's Avatar
Sanders
Rearend Gearing
Does anyboby know the gear ratio on a 68 F100? It has a 240 with a C4 and the rearend is a 9 inch. I'm thinking it is either high 3's or low 4's. Thanks
Sanders
Old Apr 4, 2004 | 10:36 PM
'70F100Owner's Avatar
'70F100Owner
Probably 4.10. My '70 F-100 came with a 240, C4, and 4.10. Now has a 300 I6
Old Apr 4, 2004 | 10:45 PM
Sanders's Avatar
Sanders
Thanks, mine now has a 302 and it lights up the back tires like a roman candle. Instead of changing the gears I think I'll just put some fat tires on it.
Sanders
Old Apr 5, 2004 | 07:28 PM
fordbeast_80's Avatar
fordbeast_80
BWAAAHHHAAHHAHAHAHAHAH , yeah put some fatties on it.
Old Apr 6, 2004 | 02:20 AM
ACESN8S's Avatar
ACESN8S
What is the axle code?
Look for a tag on the rearend and post the numbers.
Old Apr 6, 2004 | 05:10 AM
bigric's Avatar
bigric
Or post the axle code from the VIN tag.
Old Apr 6, 2004 | 12:52 PM
Sanders's Avatar
Sanders
I didn't see a tag on the rearend, but here is the VIN F10BND00524. Thanks
Sanders
Old Apr 6, 2004 | 01:02 PM
ACESN8S's Avatar
ACESN8S
Look at your drivers door. There should be a tag on the door as soon as you open it you should see it.
There will be approx. 3 rows of numbers.
Let us know what's on them.
Old Apr 6, 2004 | 03:07 PM
Sanders's Avatar
Sanders
WB-115 Trans G Axel 09 Color 6
Thanks
Old Apr 6, 2004 | 03:17 PM
ACESN8S's Avatar
ACESN8S
I show a 3.70 ratio and a C4(which you already knew)
BUT, my book has been wrong before on rear ratios......anyone verify?
Old Apr 6, 2004 | 03:19 PM
bigric's Avatar
bigric
You got it right
Old Apr 6, 2004 | 03:23 PM
ACESN8S's Avatar
ACESN8S
Thanks bigric
Old Apr 6, 2004 | 03:59 PM
Sanders's Avatar
Sanders
Does your book have color codes in it? Thanks for the gear info.
Old Apr 6, 2004 | 04:10 PM
bigric's Avatar
bigric
Pebble beige
Old Apr 6, 2004 | 06:40 PM
Mil1ion's Avatar
Mil1ion
Sanders , Maybe take a drive by Stockman's Web Site.
http://67fordtruck.com/Home.html
