Bronco II Ford Bronco II
oil sys. cleaning
Old Apr 4, 2004 | 02:55 PM
hazzard64's Avatar
hazzard64
Question oil sys. cleaning
hey all,
I'm still working on my 86' bii, there is a lot of debris in the oil, and i would like to clean the whole system, becasue i had an oil change not to long ago, about 500 miles ago. so i whats to know how to clean it out and what to use, also how much time, thanks
Hazzard64
86 bii eddie bauer 2.9efi
project for life?
Old Apr 4, 2004 | 04:52 PM
Avanti's Avatar
Avanti
trash in oil
The best would be pull the pan & replace the oil pump & screen. The next best is to change the oil again along with new filter. You could also run a quart of Marvel Mystery Oil along with the oil for a couple of hundred miles. Than change it. Do not use an oil flush cleaner as I have seen many an engine engine develope a knock after cleaning due to worn crank shaft bearings being cleaned to much.My 2 cents worth.Have a Ford that is 30 years old, 155K miles & never been rebuilt but the oil change regulary. Uses no oil.
Old Apr 5, 2004 | 07:37 AM
JimmyJames's Avatar
JimmyJames
RE: Same Concern...
I just changed my oil & added a can of Wynn's Engine Cleaner to the crankcase. A mechanic told me it was good stuff for cleaning sludge & that it's as good as the more expensive stuff out there. My oil looked pretty grungy, plus I think my lifters were a little sticky. So far, it's been running great & no more ticking!
Old Apr 5, 2004 | 10:41 PM
85B2Owner's Avatar
85B2Owner
Get a sheet of magnet and put it on the oil pan, run it with that in place and the new oil, thats will get out most of the metal shavings if any, drop the pan and replace the screen, and as mentioned earlier.
Old Apr 12, 2004 | 02:38 AM
hazzard64's Avatar
hazzard64
what kind of oil pump should i get that is the best product for a resonable price say under 70$
