Header Paint
Old Apr 4, 2004 | 07:16 AM
JakeisK98's Avatar
JakeisK98
Question Header Paint
Anyone know of a good product to use to paint headers with that won't burn off in the first hundred miles? I've had bad luck with the so called "high heat" spray paint I get at the local auto parts store and was wondering if anyone has found anything better.
Old Apr 5, 2004 | 04:41 PM
DW2455's Avatar
DW2455
other than having them profesionly coated i dont know of anything you can just spray on that will stay on, if you find something please let me know. DW
Old Apr 6, 2004 | 09:22 AM
muscletruck7379's Avatar
muscletruck7379
car craft (i think) had some header that had a special coating on them that they initially put on wrong, so it didn't last there test. but they later came back and said that they applied the paint wrong (it suposed to cook on or something) and did an entire article on applying it right, if i remember i will look in all my old issues when i get home.
Old Apr 6, 2004 | 09:54 AM
beartracks's Avatar
beartracks
To get the header paints to stick you need to sand blast the headers before painting. At the least make sure you get all the shipping paint off.
Old Apr 6, 2004 | 11:57 AM
Kemicalburns's Avatar
Kemicalburns
just pay to have them ceramic coated it will pay off in more ways then one. I priced it out on a set for about 160.
I tried many different kinds of high temp paint , will multiple coats and letting it sit and dry for a day between each coat and still burned off with in an hour of use on the motor.
late
Old Apr 6, 2004 | 02:13 PM
95 F150's Avatar
95 F150
I sand blasted my headers before I painted them then used some ultra high temp header paint and followed the directions to the letter and it worked fine for me. My wife didn't apreciate me baking my headers in the oven though LOL.
Old Apr 7, 2004 | 12:31 AM
muscletruck7379
still looking, but i know you have to bake it on...
Old Apr 7, 2004 | 08:58 AM
robduval's Avatar
robduval
header coatings
it's a little more expensive than paints but powder coating gives a nice look and the more heat you give it the harder it gets.you can either have it prof, done for relitively cheap or you can buy the kits to do it at home. if you choose to do it at home make shure you don't bake it in your oven.use an oven that you don't plan on cooking food in ever again.
Old Apr 11, 2004 | 07:27 PM
Tony G's Avatar
Tony G
Header Paint
I used por 15 factory manifold grey. That was almost 2 years ago. I had had the headers on the truck for about a year before that and they were very rusty even though they were factory painted. I had them sandblasted and then used metal ready and then painted them with the manifold grey paint. It's doing ok, but I wouldn't say it is as good as high heat powder coating or ceramic coating, but then it's alot cheaper also.
Tony
Old Apr 12, 2004 | 07:44 PM
Longneck's Avatar
Longneck
Would the 1200 degree engine paint work, or is that just for the block?
Longneck
Old Apr 12, 2004 | 08:29 PM
Tony G's Avatar
Tony G
If your asking about the por 15 1200 degree paint, I would say that it would be better to stick to the manifold paint. The 1200 degree paint would probably be for other engine components such as heads/block/intake and would probably be an extra tough paint to use in and around the engine compartment. You could call or email por 15 guys though and ask their advice.
Tony
Old Apr 14, 2004 | 12:41 PM
Longneck's Avatar
Longneck
Anyone know how hot the headers get?
Longneck
Old Apr 17, 2004 | 01:40 AM
Capone's Avatar
Capone
Not to sound like a know it all , but the temperatures inside the tube on the surface can reach 1200-1300 F depending on the tuning of the engine...
With thermal barrier coating you can protect the header tubing and increase volumetric efficiency while reducing under the hood temps by at least 100F.
it is a well known fact that for every 10 degrees F drop in underhood temps,
there is a potential increase of power by 1%.
www.techlinecoatings.com sells smaller quanities of header coatings. You may however, just send them out and get them done.
Capps in Fresno does it for the best price I have seen thus far.
Old Apr 18, 2004 | 05:00 PM
Hired Gun's Avatar
Hired Gun
LPS cold galvanize will stay put and protect against rust.
Old Apr 18, 2004 | 05:57 PM
Breeze's Avatar
Breeze
I've used "Stove Paint" made for BBQ's and such with good results. Preparation is the key tho (clean metal, no rust,oils, etc)
olblue77
Paint & Bodywork
Aug 29, 2016 11:33 AM
Colorado Highboy
Mar 23, 2016 10:22 AM
FordIowan
Jan 12, 2016 01:30 PM
chiefsfootball
42
Jul 23, 2015 06:14 PM
nlareau
Jun 1, 2011 06:33 PM
